glass shelving unit
Orbs | Posted in General Discussion on August 26, 2007 10:02am
greeting all, I am bidding a residential home remodel and need to remove a closet and install open glass display shelves. rear and left side walls will remain, new glass shelves will be 12 ft. long and 2 ft. deep. l’m looking for a nice support system, non wood, something maybe tubular.
I’m in San Diego, am familiar with Louis & Co., and Bradley’s but can’t find anything in their catalogs. any other companies or web sites would be appreciated.
thanks and happy back to school shopping to all
Orbs
  1. reinvent | Aug 26, 2007 11:53pm | #1
    These guys are kinda high end archy stuff but worth a look.
    http://www.sugatsune.com
    Also
    http://www.hafele.com
  2. Orbs | Aug 27, 2007 01:24am | #2
    bump
  3. VaTom | Aug 27, 2007 03:46pm | #3
    Objets' too heavy to just have the shelves float (anchored in the walls)?  A frame under the glass defeats it.  Really heavy objects on glass have other problems.
  4. DanH | Aug 27, 2007 05:49pm | #4
    A 12 foot by 2 foot piece of glass is pretty unstable. Hopefully it will be cut into two pieces.
    You need to determine how thick the glass will be, and how heavily it will be loaded, thus determining (presumably the glass guys have charts) how many supports are needed.
    Probably the simplest would be brass/aluminum rods inserted into holes drilled in a vertical support (aluminum bar stock?) behind the wall. Or make the support flush with the wall and part of the "effect".
    CapnMac | Aug 27, 2007 07:06pm | #5
    Well, I just punched in some values in the sagulator:
    http://www.woodbin.com/calcs/sagulator.htm
    250# on a 144 x 24 x 1.5" glass shelf is still bending 0.14"--so decreasing the span is clearly (NPI) needful.
    You might browse the Häfele catalogs online--they have a pretty good selection of glass cabinetry items.  Googling "glass store fixture" might yeild a good search for hardware that's used every day, too.
    bobl | Aug 27, 2007 08:26pm | #6
    http://www.fixturepronto.com/storefixtures.htm
    http://www.advanceglass.com/products/shelves/shelves.html#Rod_System
    when I was doing some research on glass shelving I came upon these sites.
    I know nothing about the companies.
    going 2' wide may require some custom solution
    bobl          Volo, non valeo
    Baloney detecter    WFR
    "But when you're a kibbutzer and have no responsibility to decide the facts and apply the law, you can reach any conclusion you want because it doesn't matter." SHG
