Glass Shoji source?
Philter | Posted in General Discussion on July 7, 2006 03:33am
…is needed, I have the picture from a client, but no leads as to manufacturer….
any ideas?, TIA,Phil.
“If ’tis to be,’twil be done by me.”
  1. ruffmike | Jul 07, 2006 03:40am | #1
    Try http://www.tatamiroom.com
    They have warlon, a pvc product. Traditionally shoji is paper.
    Click on shoji paper.
    I have bought lights from this site and service was good.
                                Mike
    1. Carole4 | Jul 07, 2006 03:46am | #2
      I've bookmarked this one! Thanks so much....See how much one can learn....:)
      1. ruffmike | Jul 07, 2006 04:09am | #3
        Japanese design is cool.
        Hey I just realized this is the Tavern! What is Phitter doing talking about work here?
        He owes me a Shirley Temple!
        Wait, now its back in General, I think I may have just had a flashback...
                                    Mike
        Edited 7/6/2006 9:11 pm by ruffmike
        1. Carole4 | Jul 07, 2006 05:10am | #5
          Things are moving too fast for me.....:)Those are exceptional......We visited a gallery here in Tucson where an artist had some lamps(way out of our range) that were carved out of paper......
    Luka | Jul 07, 2006 04:21am | #4
    Phil, looks like etched glass would do the trick.
    Don is our etched glass expert.
    Don, can you hook him up here ???
    Politics: The blind insulting the blind.
    1. Don | Jul 07, 2006 05:39am | #6
      Lived in Japan for a while (Okinawa). Saw a lot of Shoji screens. A Shoji is pretty large. Frame is pretty light. Glass would be a bit heavy for them. That's probably one reason why paper is used. If you go to glass, it should be tempered for safety, & would have to be 1/8 inch thick. A uniform frost over the entire area is necessary. A commercial glass provider could get it for you most likely. You definitely don't want to buy the glass from a glass artist etcher - you'd need a body guard to accompany you when you take the money to pay them.DonDon Reinhard
      The Glass Masterworks
      "If it scratches, I etch it!"
      1. Philter | Jul 07, 2006 07:07am | #7
        What about the frame?...Would this be a "stock" item available from someone?
        ....and y'all are right, it belongs up here, not in the tavern...
        Dang, all i can provide is Canadian beer, no ST's up here.....
         "If 'tis to be,'twil be done by me."
        1. Don | Jul 07, 2006 07:31am | #9
          Can't help you here. Have never seen a shoji made in USA. May be - I just haven't seen them. Yes, you can go w/an acrylic material. Don't expect to get it frosted by sand blasting - doesn'tworkverywellonthem.DonDon Reinhard
          1. MikeSmith | Jul 07, 2006 01:16pm | #10
            philter.... i'd use Kalwall fiberglass
            Solar Components Corp in Manchester , NH  ( "little Kalwall " )  makes a great 1/2 " thick  panel that looks as close to a shogi as you can get without being the real thing
            talkingdog | Jul 07, 2006 06:53pm | #11
            Warlon is the tried and true answer. We talked about this before.http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=31964.1&maxT=7I am personally interested in experimenting with a new type of shoji that is a simple rectangular frame with a piece of twin wall polycarbonate inside, clear. Inside the alternating cells of polycarbonate wooden strips are inserted. Voila, a fast and cheap modern Japanese shoji that you can build onsite. This could also be done with the milky colored polycarbonate.
    Luka | Jul 07, 2006 07:20am | #8
    How about plexiglass ?
    You should be able to find it frosted like that. The frame should be simple enough to make.
    draftguy | Jul 07, 2006 07:22pm | #12
    here's an acrylic sheet company we've specced in the past (they have some semi-transparent sheets)
    http://www.americanacrylic.com/luma.htm
    1. pgproject | Jul 07, 2006 10:49pm | #13
      Try Solex- it's plastic glazing for greenhouses, corrugated polycarbonate. relly cheap and looks great.Bill
