Does anyone know of a source for glazed brick for use on a fireplace hearth? Or is there any way to achieve the appearance of a glazed brick and still have a fireproof surface?
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
There are many mfg. of glazed bricks. Check with your local tile or masonry showrooms. What, you already did that? Okay, go to the mfg. directly; US Brick, Buchtal, etc. come to mind. These are mostly what is called a "thin brick", the dimensions are the same except for thickness, which is usually 1/2". If no luck, e-mail me, give me a few days though because I'll have to dig out the prod. lit.
*I assume you don't mean refractory brick for inside the fireplace. There are several mfr's of glazed ceramic products. One is called SpectraGlaze, although this is really a glazed CMU product. If you want an actual brick-like product, what you are looking for is "SGFT" (Structural Glazed Facing Tile), with one of the biggest mfr's being Stark Ceramics, Canton, OH (1-800-321-0662). E-mail me if you need more info.
