Glazed Ceramic Floor Tiles
user-220748 | Posted in General Discussion on October 31, 2006 12:38pm
I work for a non-profit that is renovating a house.  We received a donation of Daltile Sierra 12″ x 12″ glazed floor tiles.  Would this be suitable for a bathroom floor?  We are wondering if it would be too slippery when its gets wet.
    Dinosaur | Oct 31, 2006 01:39am | #1
    If it is a high-gloss glaze on a flat, smooth tile, you are proably right that it will be quite slick when wet. Most Daltile for bathrooms that I have installed are matte-finish porcelaine mosaïc tiles.
    Whatever you decide to do, make sure you prepare the substrate properly. 12x12's crack very easily if the floor isn't stiff enough or flat enough, and for a wet area like a bathroom you are looking at CBU's or a membrane to protect the ply.
    Dinosaur
    foolish men call Justice....
  2. FastEddie | Oct 31, 2006 01:51am | #2
    From the DalTile catalog.  Looks like it is suitable for floor tile.
    Field Tile
    Rainier
    1500
    Peach
    1553
    Jasper
    1526
    Vail
    1535
    Aspen
    1525
    Almond
    2009
    Black
    2011
    Relative Price:
    Shade Variation:
    Tile Thickness:  5/16"
    Recommended Grout Width:  3/16"
    Applications:
    View Image Residential Light Commercial Commercial
    Floor X X X
    Walls/Backsplashes X X X
    Countertops X X X
    Suitable for exterior walls in non-freezing climates when proper installation methods are followed. Use of a latex modified thin-set is recommended for installation. Not for use on ramps.
    Notes:
    • Trim P-3689, P-3681, PB-3689 and PC-3689 only available in 1500, 1525, 1526, 1535 and 1553
    Tile Sizes:
    8" x 8" Field Tile
    12" x 12" Field Tile
  3. WayneL5 | Oct 31, 2006 04:05am | #3
    I wouldn't in a bathroom.  Even a healthy person will sometimes slip up, and over the life of the bathroom you can't be sure everyone using it will be fit, sober, and wide awake.  Save it for another part of the house or a different part of the same house.
    There's no reason why you couldn't use it on a wall as far as I can tell.
    BillHartmann | Oct 31, 2006 04:14am | #4
    If you look at the footnotes it refers you to this.
    http://www.daltileproducts.com/factors.cfm
    "Glazed floor tiles should not be used where there is a consistent presence of water, oil, or grease unless COF exceeds 0.60."
    If you go through the pro, rather then the homeowner entrance I see that it gives you the tile specs.
    http://www.daltileproducts.com/series.cfm?series=32&next=19&pg=4&c=24#544
    Test Results:
    COF Wet >.50
    Dry >.70
Versatile Vise
