Glue down a Rock
PegHead | Posted in Construction Techniques on August 27, 2005 07:06am
Well, not really glue…
We are building a little timber frame bath house and would like to scribe 3 post feet onto rocks as an interesting foot/pedestool.
So here was the plan: Footers are below the granite floor, we set the stone on location with a stiff mortar mix, then drill a hole through the rock, floor and into the footer. Insert steel rod, epoxy and set post.
Seems that when the hammer drill hit the rock…bad things happened to the mortar. New plan is to drill all separate….I’ll bet you guys might have an idea or two.
I’d appreciate any advice. Picture FYI
  1. WayneL5 | Aug 27, 2005 07:25pm | #1
    Drilling separate is a good idea.  Or a core drill would drill through the entire assembly.
    If you core drill, let the hole dry thoroughly.  Many epoxies don't set well in the presence of moisure nor adhere to damp surfaces.
  2. duster1 | Aug 28, 2005 01:33am | #2
    Get bigger rock; taller and larger base to handle the load.
    ALso check FHB # 172 page 128, scribing a log post
    to match a rock.
    g-luck
  3. FastEddie | Aug 28, 2005 01:44am | #3
    Did you use a tile or brick mortar?  Might have better luck with a stronger material, like high strength baseplate grout, which woul dhave a compressive strength of something like 6000 psi.  I think I read somewhere that mortar is only about 2000 psi.
    1. PegHead | Aug 28, 2005 07:49pm | #9
      Hmmm. The point load on the post is less than 500 pounds. Do tell, the grout/epoxy seems cool....perhaps a center glop of epoxy, then pointed with mortar.I should have mentioned that we did not drill the holes with the motar green. (I'm not sure what mortar type either) Given the frame is made and part up, we set the rocks on location, let the mortar dry (3 days) then came back for the drill/pin. The hammer drill cracked em free. Too many vibes. My guess was that mortar can't handle the vibes....but I'm not a mason.
  4. Claymaker | Aug 28, 2005 07:06am | #4
    Drill separate and then epoxy. Two holes and steel rods will give better registration for scribing and fitting. Use carbon paper to make witness marks on the bottom of the post and use a rotary cutter such as a Dremel or Foredom to remove the black marks. Do this 40 or 50 times and you can get a perfect fit. I do it a lot on my work, on posts up to 12" square. Hollow out the bottom of the post about 1/4" deep after you have a rough fit, and then you only have to make the perimeter of the post match rock. It also helps to be obssesive/compulsive.
    1. butch | Aug 28, 2005 12:58pm | #5
      HOw did you get that tree to grow out of that rock :-)Man, that looks awesome
    2. PegHead | Aug 28, 2005 07:39pm | #7
      Wow, that's a cool bed of coals. Nice job.We're good on the scribe part. Good trick on the carbon paper...we use carpenters chalk. Given this lives outside and we don't want a tight inetrface with the rock...just implied, so to allow a square of ice and water between the rock and post to keep the "cold" rock away from the "warm" post. Again great work!
    3. ZooGuy | Aug 29, 2005 10:24pm | #15
      What are the (approx) dimensions of this art?
      1. Claymaker | Aug 30, 2005 03:02am | #17
        This was one of the smaller ones. I recall it being about 30" high.Clay Foster
        http://www.home.earthlink.net/~claypen
      aimless | Aug 29, 2005 11:39pm | #16
      Gorgeous!
      1. Claymaker | Aug 30, 2005 03:03am | #18
        Thanks. You can see more of my work at my website, including a church commission last year of doors and 30 pieces of furniture.Clay Foster
          aimless | Aug 30, 2005 05:24pm | #22
          What's your website? I looked at your profile and couldn't find it.
          1. Claymaker | Aug 30, 2005 09:50pm | #23
            I think I've updatede my profile, and added my website address to my signature below.Clay Foster
  5. msm | Aug 28, 2005 04:37pm | #6
    clay! that's beautiful! is it pure sculpture of it is functional too" looks like it could be a torch-
    peg, i agree about those rocks being too small in the first place. aside from practicality, they are not visually a good proportion.
    try a little experiment with a bag of cement: i've seen garden furniture "pillows" made by letting the cocrete set up inside a bag shaped like a pillowcase, nice an slumpy and saggy. you could possibly try making your own 'rocks' with makeshift molds of bags, with a dis-assemble-able box in the center to reserve a square hole for your posts
    1. PegHead | Aug 28, 2005 07:43pm | #8
      Nope. Rocks are the right size. The whole building is only 8x10 and the posts are only 6x6.Sounds like a cool idea with the CC pillow...but what's the point? why not just get a rock? As for the pocket....then the post would really rot fast...bad idea in my mind. NEVER bury a post in CC. A death sentence for the post.
      1. msm | Aug 28, 2005 08:24pm | #10
        what's the point? well, one way to solve the problems you are having, LOL
        i guess "the right size" is in the eye of the boulder beholder. the rocks in the photo do not make satisfactory plinths to my eye, but that's my personal taste. i'm an artist, so i'm picky about the visual, but it's true that carving out natural rock will make a better story to tell.
        1. PegHead | Aug 28, 2005 08:32pm | #11
          boulder beholder....That's a great line. It's like me when I look at the ladys!
          Customer picked the rocks. It's his shower.Thanks!
          1. msm | Aug 28, 2005 09:58pm | #12
            customer picked 'em-
            'nuff said. have fun ;-)
          2. mossywyatt | Aug 30, 2005 04:13am | #19
            You may want to try a morter bonder there is not much tooth with many kinds of rocks
            wyatt
          3. donpapenburg | Aug 30, 2005 06:29am | #20
            I use portland mortar on rocks that are of limestone and harder like the granite.  If you want a real good hold use a concrete bonding adheasive instead of the water to mix the mortar ,or an acrylic addative.
          4. PegHead | Aug 30, 2005 05:02pm | #21
            Well there you go...I've never hear of such.I'll check it out. Thanks! Local supply house I guess?
    2. Claymaker | Aug 28, 2005 10:53pm | #13
      It has no practical function, so it must be art. I sell my stuff through a gallery in Santa Fe, and whoever buys it can call it whatever they want.
  6. JasonQ | Aug 29, 2005 10:09am | #14
    I seem to recall FHB addressed just this very project a coupla issues back...wish my memory were better at 2AM, so's I could tell you which one.
    Jason
Versatile Vise
