Glue for MDF
ruffmike | Posted in General Discussion on January 4, 2007 01:20am
I am adding a piece of mdf (1/2″) to an attic ladder door that is luan. size 21″x 51″.
I would like to glue it and back screw it until glue holds.
What type of glue is best? Will screwing from back be sufficient or should I screw from front and fill screw holes?
The ladder is already installed in ceiling.
                            Mike
  1. fingers | Jan 04, 2007 01:26am | #1
    yellow glue
    1. ruffmike | Jan 04, 2007 02:24am | #2
      Thank you.                            Mike
  2. JulianTracy | Jan 04, 2007 03:50am | #3
    In the last glue review I read, Titebond III came in first for every possible application - interior or exterior.
    Having said that, a chunk of 1/2" MDF attic door sized will still be pretty heavy and somewhat dangerous if not fastened completely. I would prefer instead to use some thing of a construction adhesive type product plus the screws. Fully cured, it would have a ton more tooth and grab than thin yellow wood-type glues.
    JT
  3. FastEddie | Jan 04, 2007 03:51am | #4
    Yellow glue, run a couple of sheetrock screws either way, whichever is more convenient, remove the screws the next day, patch & paint.
The Trump Administration Wants to Eliminate the Energy Star Program
The end of this program will likely lead to higher energy bills and fewer business opportunities for the American people.
