Glue lam beams
horseman | Posted in Construction Techniques on July 4, 2004 02:37am
I’m going to be building a deck soon (25′ long x 15′ wide). I want to use a glue lam beam for the girder. I don’t know much about glu lam’s and was wondering if someone could tell me the sizes and thickness they come in and perhaps what thickness would be good for me to use for this size deck. I’ts a few feet off the ground and I figured I would use three footings for the 25′ girder (6×6 posts for support). Thanks.
Les
    Sphere | Jul 04, 2004 02:46am | #1
    I'd be thinkin of a triple 2x12 my self..a heckuva lot cheaper, and glulams ain't PT, and could easily DE-LAM in the weather.
    1. Piffin | Jul 04, 2004 03:15am | #3
      You can get gluelams in PY ( or used to be able to) but LVLs are easier and cheaper and can be PT too.
      For the engineering, the retailer that supplies them can do that based on a scetch with all the span info.
    2. UncleDunc | Jul 04, 2004 03:19am | #4
      >> I'd be thinkin of a triple 2x12 my self..a heckuva lot cheaper ...
      Depends on what your time is worth, or what you'd rather do with your time. I've made up beams out of 2x12s, and I didn't like it.
      >> ... glulams ain't PT, and could easily DE-LAM in the weather.
      I have no personal knowledge, but according to an article I read in a 12 or 15 year old FHB, pressure treated glue lams are available.
        jonblakemore | Jul 04, 2004 03:30am | #6
        My guess would be Lester is working solo.
        A 25' 4x16 would be pretty heavy. Another reason why I like built up.
        Jon Blakemore
    3. wrudiger | Jul 04, 2004 03:24am | #5
      Or... since it's only a few feet off the ground add a few more footers and reduce the size (and cost) substantially.  For example, go with 6 footers (5' span between footers) and a 4x6 will probably to the job.  You can use the Excel program at http://www.wwpa.org/techguide/suite.htm to confirm that your design will meet common engineering requirements for sheer, bending etc.
    jonblakemore | Jul 04, 2004 03:14am | #2
    Lester,
    I have to agree with Sphere. The only reason you would need a glulam is for appearance. Since you're deck is almost ground level, only the rodents would appreciate the material.
    I would recommend 4 footings with 3 2x12's. If you have a 1' cantilever on each end, you would have a beam span of about 7'. 3 footings would make for a beam that is a little long.
    Jon Blakemore
    IMERC | Jul 04, 2004 05:42am | #7
    Big bucks and they'll de-lam in the weather...
    Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming....
        WOW!!!   What a Ride!
    JeffBuck | Jul 04, 2004 09:45am | #8
    "I want to use a glue lam beam for the girder. "
    Why?
    Buck Construction, llc   Pittsburgh,PA
         Artistry in Carpentry
  5. DanH | Jul 04, 2004 04:57pm | #9
    About all I know about them is if they ain't PT they act like sponges.
  6. davidmeiland | Jul 04, 2004 07:22pm | #10
    A glulam is a waste under a deck. It will start to decay too soon. For your application you can probably use a 6x8 DF#1 PT supported at the ends and two mid points, or a 6x10 DF#1 PT or 6x12 DF#2 PT supported at the ends and one mid point... a foot or two of beam cantilever at either end in any case. That's according to engineered plans for a deck sitting in front of me, so your mileage may vary.
      jonblakemore | Jul 04, 2004 07:49pm | #11
      6x would work if he can get it locally. I cannot get anything like that around here unless it's special order.
      If Rez would get him to fill out his profile we could find out where he is located <g>
      Jon Blakemore
      1. davidmeiland | Jul 04, 2004 10:01pm | #12
        6x is preferable to the 3 2x sandwich because water will get in between the layers of 2x... plus no need to bolt it together
        1. DanH | Jul 05, 2004 01:55am | #13
          But on a low deck he doesn't need a 6x beam. Just add more posts.
          1. davidmeiland | Jul 05, 2004 02:20am | #14
            Every post requires a pier. Just depends on whether you'd rather dig more holes and pour more concrete, or buy a bigger beam.
  7. BUSTER | Jul 05, 2004 04:56am | #15
    Hey,  please enlighten us w/ your trib. span,  cant. (if any), o/c spacing of joists.  I can run #'s for you then.  As the others said...the glue-lam would need PT(which can still be done)..but is costly.
    Tony
    1. horseman | Jul 07, 2004 03:05am | #16
      Hey all,
      Thanks for all the replies, I was away for the holiday and this is my first visit back since the post. Basically, I wanted to use a glulam for the girder and the end joist because I was told they are very true and straight and I didn't want to have to build up a multiple 2x10's to make up the 25' length. I know they are more expensive, but for the money the timbertech is costing, a few more dollars isn't going to kill me. Have a buddy out West that swears by glulams so figured I'd give it a shot.
      Les
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
  • Natural Simplicity
