Glue Laminate PVC Trim
jimmiem | Posted in General Discussion on May 21, 2019 09:12am
I have to laminate some 1/2″ Azek PVC boards to make 1″ thick exterior window trim boards.  I would like a water-tight welded joint.  The reviews on the Azek glue go both ways.  Any recommendations on a good glue?
  1. Whitewood_Millwork | Mar 16, 2021 04:13pm | #1
    I would assume that this issue is long past solved for the author, but I thought I would throw in a glue suggestion for the next person. We laminate Azek sheet goods every day and we use Chem-Set Trim Grip. It is a two part structural adhesive that creates a permanent bond. Just clean up any squeeze out that you get before it cures. I also wanted to mention that Azek makes 1" thick material that is likely available at a lumber yard that stocks Azek.
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
