Here is a challenge I’m looking for help with.
A plastic shelf peg broke out of the plastic wall in our regrigerator. The manufacturer does not offer a repair kit.
There is some reasonable surface area to glue the peg back in, but I’m not sure what would be the best adhesive. Epoxys need warm temperatures to cure, and I was thinking a heavy bodied glue would be best. I have been looking around for a heavy bodied contact cement, I thought I saw a product ad for a cement like that. At least half of the glue surfaces could cure at room temps.
Then I thought about a polyurathane based caulk, hoping it would cure in week or so.
My wife really doesn’t want to empty out the fridge while the glue sets up.
So….
Any ideas out there?
Thanks in advance for any suggestions
jim
Is there enough body to the remainder of the peg to drill an 8mm hole and try inserting a brass or ss shelf bracket?
The shelf peg is completely broken out of the wall. The peg was molded into the wall of the fridge so when it broke out a bit of the flair at the wall edge came with the peg.
Jim
Then I'd hunt up a piece of PVC that had a flat surface and cut it in to something that would work and use PVC general purpose cement. Won't look like original but should work. I can't think of a sure fire fix to try to get a molded hook back in there with any strength. Good luck.
Hot melt glue might do it. In a pinch, I have "welded" plastic with a soldering iron, you may need to find a similar plastic , such as a vitamin bottle cap or such to use as the weld filler.
How about Gorilla?
I don't have much experience with Gorilla glue, will it adhere to plastic?
Jim
It sticks to EVERYTHING...for real. & it likes damp...& doesn't mind cool. Drawbacks are it bubbles, so don't use much, & it dries amber, which might be a drawback if you are very fussy. It is hard to get a really neat joint, but it is as strong as the advert implies. Good Luck!
Thanks every one for the ideas, I'll give the gorilla glue a try.
Jim
you also need to apply LOTS of pressure to the joint, while the stuff cures
I could wedge the peg in place from the opposite wall.
thanks,
jim
Gorilla glue is gonna dry brittle in cold...FWIW.
I like PeteVa's idea -- smooth the back of the peg and insert a ss pan head screw; then make a button hole in the side of the refrig (hole the size of the ss pan head screw above where you want the screw to end up and then a slot the size of the ss screw's shaft) so the side is supported by the screw head - Dudley
sounds better than GGlue. I hate that stuff.
Let us know the results. I've never used it and would like to hear how it turned out.
will do, i'll probably work on it tonite
jim
Use a hair dryer to heat the surface a little before you glue. I think Gorilla Glue would work also. Watch out it is messy.
