Gluing to Granite
Dirtpour | Posted in Construction Techniques on January 8, 2005 09:21am
Dishwasher silcon caulked to my granite countertop has shockingly come loose.
Plan A–Glue wood strip to bottom of granite and secure dishwasher with screws. Polyurethane glue?
Plan B–Drill holes for plastic anchors and secure with screws. Granite installer feared doing this. Should I be fearless?
Plan C–Listen to wife bitch about dishwasher rocking forward each time we fill it.
Visit from the “Bright-Idea Department” wanted.
  1. steve | Jan 08, 2005 10:06pm | #1
    i've faced the same problem myself a few time
    sort of solved it by gluing a wood strip(1/2 inch ply) with 5 minute epoxy
    unfortunately this prevents the Dwasher from being raised up snug to the top
    caulking is not a piece of trim
    james | Jan 08, 2005 10:08pm | #2
    screw thru side of dish washer into cabinets ajacent
    james
    1. steve | Jan 09, 2005 09:14pm | #3
      and use lots of caulking to prevent leaks!!caulking is not a piece of trim
        james | Jan 09, 2005 10:41pm | #4
        no caulk steve... just be smart enough to run your screws in the area on the dry side of the seal.... most dw's set the door into the frame a little and if you put your screws in on the correct ( dry ) side of the seal then bobs your uncle...
        james
        I think fisher pikel ( sp ) uses this method instead of  the cheezie top sheetmetal bendie things.
          james | Jan 09, 2005 10:46pm | #5
          I guess in my first post i should have mentioned screwing into the face frames of the side cabs, thru the dry side of the dishwasher seal.
          my bad
          hope no one went running scews thru the wet side of the seal on my account, and if you did all i have to say is DUH!!!
          JAMES
          1. Piffin | Jan 10, 2005 12:43am | #7
            I never answered 'cause you already did the right one. Most DWs I have seen have the holes already puinched in the side trim flange for this sort of mount. For those that don't ,maybe, I would use the poly glue to add wood to the granite rather than drilling the granite
  3. alwaysoverbudget | Jan 10, 2005 12:41am | #6
    i'd go with plan c, keeps her focused on that problem without dreaming up something else! larry
      intrepidcat | Jan 10, 2005 02:19am | #8
      plan "C" won't work without creating more problems. Bitching begats bitching as they say.
       "I was glad that when everything finally hit the fan I was holed up in a little beer joint in Robstown, Texas called the El Gato Negro."
  4. Neuf | Jan 10, 2005 08:46pm | #9
    Many DW manufacturers offer special brackets , attached to the side of the DW, that allow you to screw solidly into the side cabinets.  There are specifically for garanite & stone counters.  Good Luck.
    PS GE's are about 20 bucks
Picture-Perfect Pergola
