Glulam ridge beam rafter overlay or notch
lpranger467 | Posted in Construction Techniques on July 24, 2017 05:30am
 Sorry about the 1st grade drawing. But with a glulam ridge beam would it be best to notch the rafters (right side drawing) or not notch the rafters (left side) and overlay the beam then put a plate (mini collar tie) across ?
The rafters will be 2 x 10s and bottom will be covered in drywall. Lower portion of glulam will be exposed.
Thanks very much
    Mike_Mahan | Jul 25, 2017 04:29pm | #1
    Do not notch the rafters.
    Notching the rafters as you show weakens them in shear at exactly the point where shear load is greatest. Without suport here for the bottom of the rafter you invite falilure in horizontal shear as well. You could set them on top and use a ridge board that rests on the beam for maximum bearing or you could hang them on hangers. Common method of strapping is across the ridge.
    1. lpranger467 | Jul 26, 2017 07:38am | #2
      Thank you
      That was my though that the notching would cause a weak point but the framers keep mentioning it saying it will "lock" the beam in place. The glulam beam will be appearance grade so I cant use hangers which is why I was going to put gussett plates between the two.
        Mike_Mahan | Jul 26, 2017 12:29pm | #3
        Ridge board.
        You either need a ridge board or solid blocking between the rafters at the beam. Don't worry the beam will be plenty stable without the notches. If you use a ridge board just strap the tops of the rafters. A-35s on top of the beam would be a good idea.
        1. lpranger467 | Jul 26, 2017 02:43pm | #4
          Sistered rafter
          I dont think it changes anything but I'm actually opening up a flat ceiling so these 2 x 10's will be sistered next to existing 2 x 6's. The existing 2 x 6 does have a ridge board but no beam.
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
