good miter saw blade for PVC pipe?
royboy | Posted in General Discussion on May 21, 2006 06:21am
I cut & fit enough PVC to have just sprung for a cheap delta 10″ miter saw to cut it. anyone have any recommendations for a good blade for cutting it – or are framing blades good enough?
thanks – Roy
  1. DougU | May 21, 2006 06:44pm | #1
    I would want one with multi-teeth. A rip blade would be to corse and you'd see a lot of chiped PVC.
    You dont have to get an expensive blade for this but one with a lot of teeth.
  2. RW | May 21, 2006 06:46pm | #2
    Its soft enough anything will cut it, though I suspect that a blade originally designed for plastics (they are out there) will cut it longer and cleaner for the same blade price. If you don't see one that says plastic, a melamine blade would be a close second.
    "Sometimes when I consider what tremendous consequences come from little things, I am tempted to think -- there are no little things" - Bruce Barton
  3. junkhound | May 21, 2006 09:52pm | #3
    Believe it or not, the 10 inch $8 (on special sales) 60 tooth carbide blades from Harbor Freight do a superb job on PVC. Price is right.
  4. JonE | May 22, 2006 01:03am | #4
    I have a 60-tooth Freud Diablo on my miter saw and it works great for cutting PVC.   Reasonably cheap at Home Depot or online.  You get little tiny PVC shavings instead of dust.
  5. royboy | May 22, 2006 03:35am | #5
    thanks, guys. sounds like it won't be too tough or expensive.
    Roy
    1. BryanKlakamp | May 27, 2006 05:48am | #6
      As was mentioned, a carbide blade with more teeth wll cut fine. Just watch how fast you cut.
      Another blade you might consider is a triple chip tooth blade. These blades are meant to cut plastic and non-ferrous metal. You will get a cleaner cut, and they won't catch the pipe and throw it as easily. They are more expensive, though.
      Bryan"Objects in mirror appear closer than they are."
      Klakamp Construction, Findlay, Ohio
  6. michaelgray06 | Mar 06, 2021 11:17am | #7
    I read a well about it, where they are explaining some of the best miter saw blade for PVC pipe. You can follow that list:
    1. IVY Classic 35056 Swift Cut 10-Inch
    2. SHDIATOOL 7 Inch
    3. Freud 10 In 80 Tooth
    4. SHDIATOOL 4-1/2 Inch
    5. LASCO 13-2998 Metal Inside Plastic Pipe Cutter
    To know details about each of the blade then you can read their article:
    https://vinosalrio.com/best-miter-saw-blade-for-pvc-pipe/
