Good quality & secure patio door
housenut1 | Posted in Construction Techniques on September 6, 2010 04:23am
Who makes a quality exterior  patio door? Are some more secure than others?  How hard is it to break the tempered glass to get in?  My first thought was a french door style but If one fixed and one operable is better I’ll go with that.  A slider is definitely out.
 It will be serve as an entry/exit door to an unheated covered porch in Chicago.  Also  Our home is 80+ years old and we would like to keep the character of the house,
Wayne
  1. calvin | Sep 06, 2010 05:16pm | #1
    We've had a Marvin
    on our home now for 20 yrs.  Works well, weather secure-ordinary deadbolt is the security.
    There's a couple 3 point locking systems that might be considered more secure-Pella and Andersen.
    What does it take to break tempered?  One of those automobile hammers and of course the pc. of gravel expelled by a lawnmower.  Usually breaks the first pane-another tap or rock for the second.
    1. housenut1 | Sep 07, 2010 10:04am | #3
      Calvin:
      Thanks for the advice.
      Wayne
  2. DanH | Sep 07, 2010 09:12am | #2
    We have a 34-year-old Andersen slider that's still in good shape.
    Tempered glass is not security glass.  Tempered glass is a bit tougher than regular glass but not that much -- the tempering just makes it break into small, relatively non-hazardous pieces when shattered.  If you want security glass you'll have to order it (for extra $$).
    A double French door with no center jamb would tend to be less secure than an single door.  But partly it would just depend on available styles, since security doors will be a more limited selection than your garden variety doors.
    1. housenut1 | Sep 07, 2010 10:05am | #4
      Dan:
      Wayne
      1. gfretwell | Sep 07, 2010 03:52pm | #5
        If you are looking for security buy a wind code door with impact rated glass. That will stop most assaults but it ain't cheap..
        1. housenut1 | Sep 09, 2010 10:33am | #6
          Wayne
  3. Clewless1 | Sep 09, 2010 10:36pm | #7
    I've got a pair of Doug Fir Marvin french doors that have a center secure lock between them.
    As far as the glass and security ... the glass isn't like your car windows ... can break fairly easily with a sharp (relatively) object like a hammer ... even though you might be able to take that same pane of glass and support it between sawhorses and stand on it w/out breaking (I've seen a picture of this).
    On the other hand, you do have glazing options:  laminated glass or wire glass. Both provide a much higher level of security and are common glass options available for you to order if this is a concern.
    Last option (and least, by the way). Use security bars over the windows. Not what I might recommend unless conditions are extreme and I'm assuming (there's that word) they aren't.
    1. housenut1 | Sep 13, 2010 08:31am | #8
      door tip
      Thanks I may be looking into the laminate glass.
      Wayne
  4. HaddonWindows | May 03, 2011 05:06pm | #9
    Secure Patio Door
    If security and performance is important, take a look at our SecuraSeal Sliding Patio door.    It features an integrated locking system that is far superior to a single or multi point latch hook system.    Additionally, it sports a durable and high performing composite frame system.   More info can be found at  http://www.haddonwindows.com/secure_patio_door/default.htm
    If you have any questions, just email us at [email protected]
