Can a grab bar be installed in an existing home fiberglass shower unit?
Any tips?
Any tips?
Yes.
I only agree with parts of that anser!
TRIGGER
Yes, it can, but I understand the concern - many units stand off of the studs a good distance. I wouldn't anchor to just the FG. That wont last long. I can't say I've had to do it without access to the unit itself or the backside, at which point I've PL400'd a 2x6 as long as I can to the back where the bar will go and screwed into that. And obviously, if possible, tie in to the walls. I don't know what Id tell you if access back there isn't an option. Guess let the HO decide. Cut walls behind it or not do it.
If there's more insightful ideas, I'll also be interested.
"Sometimes when I consider what tremendous consequences come from little things, I am tempted to think -- there are no little things" - Bruce Barton
If the fiberglass is reasonably thick (ideally at least 1/4") and not too floppy where you'll be installing then Wingits will do a fine job.
http://www.wingits.com/index.html
The wing its look good for the job.
I did it yesterday and got permission to open the wall from the back side and install backer 2x6.
I talked them into leaving the back open with only AC ply to cover, screwed on. That way it's still open for the future if needed for anything. Oh, and the back is in a closet; perfect.
http://grungefm.com
