My client has 25 1/2″ wide, 3/4″ thick granite slabs she wants installed for counter tops at her bar. She wants a 12″ overhang.
I was told by the granite installer that it was not a problem to extend 12″ of granite as long as it was supported by 3/4″ ply.
Is this true? I have never extended granite, having used it mostly over kitchen and bath cabinets only.
Thanks for any response.
12 inch should not be a problem with the ply supporting it. if you wanted to go a little stronger you could put corbles under it to help in the support. ( in case you are worried about someone dancing on it.
