Granite repair
Jonah | Posted in General Discussion on December 11, 2006 06:41am
Need to repair a broken granite counter top. Its not something I’ve done before.  Any advice?  Thanks.
    IMERC | Dec 11, 2006 06:50pm | #1
    how broken is it???
    WOW!!! What a Ride!
    1. Jonah | Dec 11, 2006 06:58pm | #2
      Snapped clean ooff.
        IMERC | Dec 11, 2006 07:07pm | #3
        how big...
        1. Jonah | Dec 11, 2006 07:23pm | #4
          L shaped piece with 2 legs 8" and 12"
            IMERC | Dec 11, 2006 07:40pm | #5
            corner?
          2. CAGIV | Dec 11, 2006 07:44pm | #6
            replace it
            IMERC | Dec 11, 2006 07:54pm | #7
            maybe...
            let's finish pulling hen's teeth...
          4. Jonah | Dec 11, 2006 07:56pm | #8
            Any experince with the Akemi adhesives?
    IMERC | Dec 11, 2006 08:09pm | #9
    we're not done pulling hens teeth here...
    we need all the facts...
    WOW!!! What a Ride!
    1. peteshlagor | Dec 11, 2006 08:13pm | #10
      Like what type of granite?  How bad is the crack?  Picture?
      But we should consider how available the actually matching replacement stone is.
        IMERC | Dec 11, 2006 08:47pm | #11
        yup..
        will the repair be visable...
        what is the support at the break's location...
        is the repair gonna be cantilevered..
        does the OP have the ability to to foll and polish out the crack...
        what tools and equipmwnt does he own...
        we need the full picture here...
        you must have noticed there is a rash of cryptic threads...
        this one we "get 'er done"...
        1. peteshlagor | Dec 11, 2006 09:30pm | #12
          Seems like a fairly large cracked off piece.  Leads me to think (can only assume without more info) that the original install was "inexpensively done."
          The stone work I've had done has used epoxied dowels imbedded at stress points.
          Since a correct repair of this crack involves all you mentioned, plus the stone should be pulled and turned upside down to be doweled, one's back at your first post.
          Replace it.
            IMERC | Dec 11, 2006 09:37pm | #13
            let's see if he comes back with some answers..
          2. CAGIV | Dec 11, 2006 10:58pm | #14
            couple of thoughts.
            Not to sound dickish, but if the guy is asking the question he most likely does not have the equipment of the background to pull of a repair if it is in fact possible.
            Second, is this his house or a customers?
            If I broke I piece of granite or other stone counter clean off, into two pieces, there is no way I would pass of a "repair" job.   I've seen some stone guys pull of some pretty damn amazing stuff, but if you look close enough you can see a repair...
            guess who's going to be looking at?  and who's going to think about it all that time?
            it isn't worth the ill will it would create with the customer.
            Yeah granite's expensive and heavy, oh well, consider it tuition.
            There is no way you are going to "seam" a jagged edge and make it look good IMO
            This also brings me to a few more questions, did it break during installation or was it an un-supported edge that snapped off with pressure/weight applied, some sort of freak impact?  what broke it.    If it was an overhang that snapped then that needs to be addressed as well so it doesn't happen again.
            But no matter what, replace it.
A Practical Perfect Wall
  • The New Old Colonial
