Grass click-lock cup hinges
lowercanada | Posted in General Discussion on October 30, 2019 09:58pm
Anyone ever uninstalled Grass click-lock hinges? I managed to get in touch with a nice, responsive customer service rep. who even sent some pictures, but it seems as though there’s no way to get these out of the hole without metal chisels and dremel cutting wheels.
  1. carver | Oct 31, 2019 02:52pm | #1
    What????
  2. DanH | Oct 31, 2019 09:00pm | #2
    Can you link to a picture of such a hinge? All the Grass hinges I've dealt with are secured with obvious screws.
    1. lowercanada | Oct 31, 2019 10:55pm | #3
      will post one tomorrow...
  3. MattMillham | Nov 01, 2019 09:22am | #4
    Assuming these have decorative caps to conceal the screws - have you removed the caps and still don't see screws?
  4. lowercanada | Nov 01, 2019 12:48pm | #5
    no caps, no screws....
    unfortunately I don't have an un-mounted one to look at, or a mounted one I can do a bit of exploring on.....
  5. Gramps2 | Nov 01, 2019 06:22pm | #6
    I spy a blue plastic thingy. Use a small flat blade screw driver and pop that out and I think all will be revealed!
    Good luck!
  6. lowercanada | Nov 04, 2019 08:26am | #7
    blue painters tape....pop that off and all you reveal is a cup....and it is literally a cup....
  7. MattMillham | Nov 04, 2019 09:23am | #8
    That looks like one that twist-locks into a metal cup - no screws, it just kind of press fits. Try rotating the hinge counterclockwise - should take less than a quarter turn to disengage, supposing there aren't detents preventing rotation. I'm guessing there's something like this (see pic) holding it in.
  8. lowercanada | Nov 04, 2019 09:18pm | #9
    yes, that looks like it.....but I got the sense from talking to the rep that there are indeed detents....he sort of implied that removal was a "surgical" process.....
  9. DanH | Nov 04, 2019 09:46pm | #10
    Looks similar to this:
  10. lowercanada | Nov 06, 2019 10:49am | #11
    that would be it...near as I can tell it has a positive locking method.....and a negative unlocking one :-(
