grease for Skilsaw reciprocating saw
Hi all,
I have a Skil #577 reciprocating saw – like a sawzall but more of a jigsaw configuration. What kind of grease should the crank box take?
Thanks,
Scott
Here’s link to phot of one like it:
http://cgi.ebay.com/RECIPRO-SAW-by-SKIL_W0QQitemZ130131769159QQcmdZViewItem
OWNER'S MANUAL & PART LISTS
Make the most of your Skil tools. Review owner’s manuals and parts lists online by searching in the desired tool category.
If you're looking for an older model that isn't listed, call 1-877-SKIL-999 (1-877-754-5999) or email Customer Service.
http://www.skiltools.com/en/CustomerService/PartsListsOwnerManuals/
Thanks,It is older than what they have manuals for online, so I called. They said the crankcase can be lubed with wheel bearing grease. I used Slick50 wheel bearing grease with Teflon. It is the same greenish color as the stuff that was in it before. I also added some grease between the spring steel thrust plate and the cover plate, to help conduct heat to away from the moving parts.
Edited 8/8/2007 6:33 pm ET by prairiescl
