Grease my Bulldog?
PaulC | Posted in Tools for Home Building on May 21, 2007 10:00am
I’ve got a 7/8″ Bosch Bulldog with a chipping function. Just used that feature for the first time today, and oil seems to be leaking from the chuck and running down the bit. Never happened when I was making round holes. Is this normal? Do I need to re-lube it somehow? How? Or is this a Very Bad Sign?
Amateurs talk strategy, Generals talk logistics.
  1. Hudson Valley Carpenter | May 21, 2007 11:51pm | #1
    Sounds like your bulldog is more into chipping that he is into drilling holes.   ;-)
    dieselpig | May 22, 2007 01:05am | #2
    Was it running hot?  There's usually a lot of grease in a hammerdrill chuck which does sometimes melt out when it's running too hot.  I've got a larger Bosch hammerdrill and it came with a tube of grease.  Still got your owner's manual?  That'd be the right place to start.  If you don't, I'd bet it's online on the Bosch website.
    jase | May 22, 2007 02:42am | #3
    I'll second what dieselpig said. I've got the same roto-hammer. I used it for about 30 minutes today and it go pretty hot. However, I didn't have any grease running out today. The bit was clean when I stuck it in the tool.
    Jase--Is there a better way?
    1. MSA1 | May 22, 2007 03:46am | #6
      The bit should have been greased when you put it in. At least thats what my owners manual says. I think they tell ya to lube everytime you put a bit in.
      BTW The grease always gets hot and runs down the bit on mine.
  4. IdahoDon | May 22, 2007 03:01am | #4
    That's common and to be expected.  I suppose there's no harm in adding more lube, but many guys I know assume the whole critter will be worn out by the time lube in the chuck makes any difference.  The owner's manual should say something if more grease is recommended.  If you're concerned lube it anyway.
    Best of luck.
    1. PaulC | May 22, 2007 03:43am | #5
      thanks. it was pretty hot, but it's still chugging away, so i'll leave it for now. instructions indicate to lube when replacing the brushes.
      thanks all!Amateurs talk strategy, Generals talk logistics.
      1. IdahoDon | May 22, 2007 04:11am | #8
        I was secretly hoping you would post what the instructions suggest.  At the rate the brushes are wearing the whole works will be pretty worn out.
        1. rasconc | May 23, 2007 12:25am | #10
          http://66.77.255.87/Images/BOSCHPDF/11224VSRC_pdf/PDF_MANUAL/11224VSRC.pdf
          Page 7
    IMERC | May 22, 2007 03:49am | #7
    good chanceyur front seal is history..
    WOW!!! What a Ride!
  6. toolbear | May 22, 2007 04:45am | #9
    Remember to grease the bit a bit. Hilti sells a nice little can of bit grease. Rub a bit on the SDS portions and you can have hot grease mixing with rock dust. Our new Hilti came with a Hilti towel to use with the grease.
    The ToolBear
    "Never met a man who couldn't teach me something." Anon.
FHB Podcast Segment: Patching Drywall Near a Shower
Learn how to patch drywall above a fiberglass shower without totally redoing everything.
