Green VS Yellow Bag?
Abe | Posted in General Discussion on November 19, 2005 11:11am
Quick question, is there any difference in softener salts?  I have been buying the green rust remover salt bags from Morton for my softener.  Are they actually any better? or is it like buying premium gas and putting it in a Tempo?  When I buy salt. I usually have 2-3 choices, yellow the regular stuff, green rust remover, and if I remember right blue system saver.
I am on city water and it is coming from a new treatment plant 1 1/2 miles away, but the mains are old and the flow has been reversed.  Rusty water with black specks of rust.  The softener works fine and I added a cartridge filter right after the meter so that the softener is not working as a filter for the bigger chunks.
  1. WorkshopJon | Nov 19, 2005 11:22pm | #1
    If you have iron in your water, use it, if not , don't.  No different than your gasoline example.  High compresion=high octane....low=87.
    WSJ
    1. ChuckW | Nov 21, 2005 03:05am | #4
      Your analogy is not correct.  Forced aspiration engines often have low compression and require high octane.  (Sorry, I couldn't let that go.)
      1. WorkshopJon | Nov 21, 2005 03:40am | #5
        Your analogy is not correct.  Forced aspiration engines often have low compression and require high octane.  (Sorry, I couldn't let that go.)"
        Chuck,
        I'm currently building a 1,300HP NOS'ed 496 CI BBC for my ''71 Chevelle that I've owned since '79.  Anything else you want to tell me, that I don't already know?
        Maybe you can give The BOSS lessons on how to design trusses, or Stan F lessons about stair building.
        Seriously though, If you're going to pick a fight, know your opponent.
        WSJ
  2. andybuildz | Nov 20, 2005 02:30am | #2
    Quick question, is there any difference in softener salts>>>>>
    Depends if you use it as a suppository or orally
    Be well
    a...
    1. WorkshopJon | Nov 21, 2005 01:14am | #3
      Depends if you use it as a suppository or orally"
      Andy,
      LOL
      Jon
