Grisham security/storm doors
RichBeckman | Posted in General Discussion on July 13, 2007 05:44am
I have a customer who wants a security storm door.
Grisham is the only one I can find locally (a special order at Home Depot) that actually uses the word “security”.
Anyone use these? Are they any good?
The door my customer likes is $488. So I’d like to have some more info than the trifold brochure that Home Depot had.
There does not appear to be a web site for the company. That seems to be a pretty big lack at this point in time.
Rich Beckman
Coming to the Fest? Don’t forget pencils!!!!!!!!!!!!!
  1. alwaysoverbudget | Jul 13, 2007 06:30am | #1
    i have had 2 of these doors. made of about7/8 x 1 3/4 steel frame work they are very sturdy.as good or better than any storm door out there as far as ridgid frame goes. they have a impressive deadbolt mechanism. probably the weakest link is the door jamb they slide into,pretty much a standard type storm jamb.
    they would keep someone from coming up and jerking the door open easily,bottom line is if they pop the glass the deadbolt is for looks anyway.
    if you don't mind paying for them i would recomend them for a good door,but lock your main dead bolt at night. larry
  2. BUIC | Jul 13, 2007 05:58pm | #2
      High security storm doors are common in NYC and it's boro's.  Maybe someone can steer you the in the right direction.
      This is also an unofficial "rez" (bump)...buic
    BarryE | Jul 13, 2007 06:03pm | #3
    I like his books, never tried his doors
    on the other hand you used the phrase:
    Barry E-Remodeler
      RichBeckman | Jul 13, 2007 07:09pm | #4
      "on the other hand you used the phrase: special order at Home Depot"
      Yeah, I know. I avoid the big boxes as much as possible. And I especially try to avoid them when it comes to special orders. But sometimes...It is because it is a Home Depot special order that I am trying to find out as much as possible about the door from anyone other than Home Depot. I want to know what I want before I go in there to order it.The only problem I've had with a special order at a big box was when I ordered two tubes of caulk and got six (I got two tubes three times).The only time I did a special order at the local plumbing supply house, they got the wrong toilet (and they didn't call me when it came in, and they didn't call me when the replacement came in....even the big boxes call when the special order is in).
      Rich BeckmanComing to the Fest? Don't forget pencils!!!!!!!!!!!!!
        BarryE | Jul 13, 2007 07:41pm | #5
        I hear you, just couldn't resist a little yank. <g>Never used Grisham. Only security door I've used is the Larson with the 3 point latch and the bars. Probably calling any storm door secure is a misuse of the word, but the client gets the perception I guess and it seemed solid
        Barry E-Remodeler
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
