Grizzly Shaper
| Posted in General Discussion on June 30, 1999 07:15am
I have just been given a Grizzly wood shaper, Model G1024. ANyone familar with this machine?
Unfortunately, the manual is missing.
Anyone have one I could copy?
Secondly, there is some rust on the work table. I would appreciate any tips that have worked for you in cleaning up a tool table. Thank you.
  1. Guest_ | Jun 29, 1999 09:13am | #1
    Jerry, contact Grizzly for the manual, this would be of benefit if there's a recall, or upgrade in the future.
    Wirebrush, steel wool, emory paper on a block.
    There's a decent tabletop rust preventer available through most woodworking supply houses. An aerosol spray, Bostick "Top Coat"
    and it works. Same company makes a blade/bit coating spray as well. Avoid WD40 and the like.
    1. Guest_ | Jun 30, 1999 07:15am | #3
      *Jerry,Naval jelly works well on the rust. It's very caustic so use gloves and don't leave it on too long. Then a quick rinse and polish it up with the emory cloth on a block of wood , as George suggests.If Grizzly has a website why don't you email them and ask for a copy of the manual?Richard
  2. Jerry_Levine | Jun 30, 1999 07:15am | #2
