Grout – sanded vs unsanded
| Posted in Construction Techniques on December 14, 2004 04:26am
Doing a shower enclosure and a bathroom floor, using 12″ travertine tiles with an 1/8″ joint.  I would prefer to use unsanded cuz I find it easier to work with.  Is there any reason I need to use sanded?
All I know, I learned from Luka.
  1. kcoyner | Dec 14, 2004 06:17am | #1
    sanded and unsanded has to do with the size (width and depth) of the joint.  Check the manufacturers recomendations.
    kcoyner
    JDRHI | Dec 14, 2004 06:20am | #2
    Ya might get away with it on the walls....dunno if its gonna hold up on the floor though Ed.
    I also don`t know that I`ve ever seen natural stone grouted with the unsanded......the aesthetics might give me reason to pause.
    I`m also wondering why you find the sanded harder to work with?
    J. D. Reynolds
    Home Improvements
    "DO IT RIGHT, DO IT ONCE"
    Mongo | Dec 14, 2004 07:36am | #3
    I'm in with Jaybird.
    Manufacturer's recommend you can use sanded down to 1/8th inch, and I prefer sanded on floors.
    Last week I grouted a fireplace that had a veneer of slate 1-by-3's (actual 3/4" by 2-3/4"). The grout lines were 1/8th to slightly less than 1/8th inch, maybe down to 3/32" or so.
    Got the right tools? A good grout float makes all the difference. I have two, a regular-sized float, and a margin float.
    Like buddah.
    Edited 12/14/2004 7:11 am ET by Mongo
    1. FastEddie1 | Dec 14, 2004 08:32am | #4
      Yeah, I was leaning toward sanded for the floor.  Don't know why I can work unsanded easier, but it sure is smoother material (duh! there's no sand in it).  The other bathroom floor I did in this house, we used 12 inch porcelain tiles with 1/16" joints and unsanded grout, came out real nice.
