Grout sealer for showers
terryb | Posted in General Discussion on February 8, 2015 09:33am
What’s the best sealer? I’m interested mostly in longevity. Would like to hear from pros who’ve seen long term results. Thanks
  1. DanH | Feb 08, 2015 10:17pm | #1
    What do you expect the sealer to do?
  2. mark122 | Feb 09, 2015 07:48am | #2
    what do you mean by long term? i read it as you are looking for a sealer you put on once and presto...no more sealing for the next decade.
    All the sealers i have used range in re application time but we usually try and seal our bathrooms once a year.
  3. sapwood | Feb 09, 2015 11:46am | #3
    Use epoxy grout. Then you won't need a sealer.
    1. terryb | Feb 09, 2015 01:03pm | #4
      Already grouted with sanded grout. Trying to avoid the black stuff that grows in the grout eventually and to have it last a long time.
    deadnuts | Feb 09, 2015 01:48pm | #5
    may have to modify your expectations
    If you were truely "interested mostly in longevity", then you would have researched this question before you grouted-- and not after. You've effectively limited your options at this point. Also, there are other factors that can have an effect on mold or mildew in your shower besides how well your grout or sealers perform. For instance, water proofing membrane methods (traditional mud set membrane vs. surface water proofing membrane), proper drainage, and adequate ventilation all can play a role seperate from grout. They should have been researched before hand as well.
    At any rate, I believe your options now are limited to a variety of penetrating sealers that probably have to be rejuvanated periodically. Also, you should be aware that a penetrting sealer may adversely effect the finish or look of your finish material  that is grouted.
