Gutter guards
bradbench70 | Posted in General Discussion on May 30, 2016 08:27am
I need to install gutter guards on my 2 story home and wondered which are the least problematic.  I don’t mind a little maintence trip to the roof every so often but don’t want to install something that requires trips up there several times a year.
Thanks,
Brad
  1. DanH | May 30, 2016 01:22pm | #1
    I've had pretty good luck with the plastic things you get at Home Despot, about 3 feet long with a diamond grid and something like fiberglass screen on top of that.  They fit my aluminum K-style gutters pretty well, though it's necessary to notch out the pieces where the nail ferrules are, so they will snap on cleanly.  (A pair of plain old wire cutters work for notching.)  Since they're in short pieces you don't have to wrangle great lengths of the stuff while installing, and if you get the joints tight there's little trouble with stuff leaking through.  And it's fairly easy to remove a section when you need to clean below.
    I think this is what I've used:
    There are also versions of these things without the screen on top.  They work pretty well but the grid loads up with maple seeds fairly quickly.
  2. junkhound | May 30, 2016 10:24pm | #2
    What type trees?
    If Alder, d fir or hemlock, nothing I've ever seen keeps alder polen out nor hemlock needles, a few do keep 80% of fir needles out.
    This spring, alder pollen so thck there was 1/2" deep sludge in bottom of gutters, all a gutter guard wold do is make it harder to clean.
    1. DanH | May 30, 2016 10:31pm | #3
      The plastic screens I described have a fairly fine screen on top.  Does a fairly good job with pine needles, though I'm not familiar with the attributes of hemlock.
      1. junkhound | May 31, 2016 06:29am | #4
        Hemlock has a lot of short 1/4" long, fine, flat type needles. They will follow water flow around the edges of the overflow type protectors and go thru anything more coarse than window screening.
        Pollen here will go thru window screen even.  The pollen is only a 2-3 week spring time event, it there is a wind before a rain it will all blow off the roof, otherwise washes into the gutters.
        I like my trees (about 25 ea 100 to 160 ft tall D Fir within 30 feet of house), so have deck 100% along wherever there are gutters with 2x4 step on railing to be able to reach gutters for easy cleaning.
        Nope, in 43 years, have never had one fall on house.
        user-2409187 | Jun 08, 2017 08:53am | #5
        No to plastic!
        First of all, gutters are an invention of satan :) Plastic screens are lousy, and the screen material glued on will delaminate all too soon. Squirrels love to chew through the plastic. Birds peck at it. Forget it!
        Try a fine-filtered screen made entirely of galvanized metal or aluminum. Menards sells both. Yes, they cost quite a bit more than plastic. The comments made by others regarding the kind of trees nearby should not be disreguarded. There are some trees whose droppings even the best guard can't handle. A  minimum yearly check-up/cleaning is advised. Remember, no matter what Gutter Helmet and other manufacturers claim, there is no such thing as a maintenance-free gutter!
Pressure Washing Made Portable
This electric pressure washer is compact, lightweight, and easy to maneuver.
  • Tall Deck on a Sloped Lot
  • Making and Installing Wood Wall Paneling
  • Hand-Sanding Hack
