Gutters on an Angled Fascia
PatchogPhil | Posted in Construction Techniques on May 6, 2002 06:08am
If your fascia is angled inward,  meaning the rafter tails are cut 90* with the roof angle,  what method(s) should be done to attach gutters?
Do you pull the whole fascia off and reinstall with angled blocks to make the fascia staright up and down?
Or do you put blocks every so often on the fascia surface so the gutters install straight?
I have looked (but I’ll guess not hard enough) for gutter installation brackets that are for this situation.
TIA
Phil
  1. grantlogan | May 07, 2002 08:36pm | #1
    There is a hanger made for that application for half round gutter(#30 shank).
    http://www.bergerbros.com/products_halfround.html
    gl
    I've told you a billion times not to exaggerate.
Versatile Vise
