I may have made a mistake by moving my gyrocopter to my stairshop so as I could finish building it this winter.
I guess it doesnt matter what I work on…just so it climbs and goes in circles…
I am presently installing all the instruments. I have all the switches, circuit breakers, and radio yet to install and wire.
I thought I would never find anything more enjoyable to work on than curved stairways…I was wrong
wow !.... i don't know , stan.... a twin seater ?... you are movin up in the world
Mike: It is a two seater...fully enclosed heated cabin...I dont have the doors or windshield in it yet...as all the flight controls. Lots of "fun" work this winter.
I was able to sell my other one at a nice price...and I really got a good deal on this unfinished brand new kit.
That's pretty cool Stan, Now you can take me for a ride. don't forget your cell phone so I can talk you down to my helicopter pad in my front yard.......
You're really going to like the views around here.
See you next spring. "Rather be a hammer than a nail"
Bob
Stan, your shop is depressingly neat.
Nice project. My BD5 never looked as interesting as this does.
Joe H
Stan,
I'm really impressed that you built this beauty just so you could take me for a ride.
let me know when it's ready to go, so I can book a flight up.
Oh yeah, thanks for your comments about my roof framing math in the "favorite poster" thread.
Ken Drake
Stan,
Is that engine a motorcycle engine or is it made by BMV as an airplane engine?
Larry: The engine is a 130 horse 2.2 liter Subaru engine.
Stan that is WAY COOL!!!
But....................
It needs.................
A custom bent-lamination dash board......................
AND...................
Some Kickasss Flames by KiethC !!!!!!!!!!!
I'm sure if you offered him some free rides, He would consider.Mr T
Do not try this at home!
Mr. T.....there is one piece of wood on this machine.. a 1x2 that is "straight"....and it sits under the fuel tank.
See!
I told you it needs more wood!Mr T
Looked like a BEEMER
I had some down time waiting on stair materials..so I got some "up" time and worked some more on my gyrocopter. I installed some more switches and circuit breakers..and now have the cyclic controls installed. The throttle and carb heat are now working..and the roll and pitch trim box in the center is about done.
I do not know what is causing those annoying blobs on my photos..I cleaned the lens..and no luck.
Keep em coming Stan, thanks for sharing
What are some of the stats on this one,
How fast do you think she'll go?
What kinda of range,altitude?
How soon before you have her finished?
Inquiring minds want to know
butch: It will cruise around 70 - 75 mph. Top speed is around 100. It will fly to 10000 feet. I should have it running by the end of January. Lots and lots of stuff to get just right. You have to be patient and not rush any of the details.
Stan - I hate to tell you this, but you made a mistake building it in your shop. Now you'll have to take the roof off to fly the thing out when you're finished...
Stan,
does the throttle function like a collective? How do you adjust attitude so as to climb? Just pull back on the stick, and the blades tilt back?
Do you work the throttle, or adjust the attitude to control airspeed.
How does that thing work?
It is beautiful.
Stef
Stef: The throttle only controls the engine speed which drives the propeller through a reduction drive. The rotor is NOT powered. The cyclic controls..( joystick) , tilts the rotor head the direction you want to go. Tilt left..and you go left...
Altitude is more a function of the throttle setting..and speed is more a function of the tilt of the rotor. Its hard to explain but it all balances out while you are flying. If you want to climb...adding power will get you there.
The aerodynamics of a rotor blade have always fascinated me. The laws of precession, p-factor, dysymetry of lift,torque are all demonstrated every time I fly.
I just am bent to go in circles I guess. :)
Edited 12/13/2003 6:01:25 AM ET by Stan Foster
Stan -
I don't know how common it is (was?) but at least a couple of gyros used a mechanism whereby the motor was connected to the rotor to bring the rotor up to speed to give a more verticle initial take off. I believe it was not connected for regular flight. I assume the mechanism to do this added weight, cost, and complexity and thus it probably wasn't a big seller...
Casey: Most gyros have a pre-rotator. Mine is so equipped as well. This is used to spin the rotor up on the ground to around 200 rpm. Then the takeoff roll begins and the incoming airflow passing over the rotor blades speeds them up to flight speed. The pre-rotator is not used in flight.
Some gyros have a pre-rotator capable of over speeding the rotors...then collective pitch is applied to the rotor blades and a jump take off is possible. This basically uses the over spun rotors momentum to lift the craft off the ground and into forward flight where the rotor is just then in a state of autorotation.
Ok....my stairshop is in full production once again. I have been working nights and weekends the last two months and I now have my gyro running. It is shown here tied to a tree as I have to run the engine 20 hours at ever increasing rpm's to break-in the engine. The front fairing..and the rotor are not on. The engine is running at 2700 rpm in this picture.
Did this critter do something not so nice that it had to be leashed.
That is some ride you put together Stan.. Nice work but that seems to be your norm.
Thanks...it was keeping me from my stairwork...so its back to the hanger for it.
It looks like it would be happier as a 'free-range' gyrocopter.
Ok Stan - once again I'm impressed with something you've built. Now if you're done with that break-in can we get some bird's eye views? I've really missed you taking us along on your wild blue yonder adventures.Kevin Halliburton
Kevin: I wont be able to get it legal to fly with the FAA until up in Feb. Then I jsut have to cautiously check it out on the runway. I probably wont be airborn till March.
Kevin: I will post some pictures I took last July in Indiana where I flew to a rotorcraft convention. The first is when I arrived. The second picture is base leg for runway 18. The third is on final for runway 18. The last picture is some of the gyrocopters on the flight line. Mine is the little red one clear at the back.
Thanks for the fix Stan. That'll hold me till the FAA gives your current bird her official wings.
You're one of a kind man - glad I found your little corner of the world here. Your stairs, your son's health and your pictures from above - I seem to find a level of inspiration in every one of your posts.
Ah-Pree-shate-cha!Kevin Halliburton
Kevin: Thanks....My son getting his health back has caused my life to climb higher than any stairway or gyrocopter can get me.
I finally got my front fairing on and the machine cleaned up. These are similar pictures that I had posted...but it is finally the way it should look. I have to give it its hang test yet...then its up to the airport.
Simply awesome! I know you must have posted before but how much runway do you need to take off. I have a 400 + foot run before I hit the tree line, is that a safe distance or would I need a better helmet? How about the noise, ear protectors required? How loud is it to people on the ground at takeoff?
Armin: It takes several hundred feet to take off....unless there is a good headwind. It will land in very tight places..usually rolling less than ten feet.
The rotor is first pre-rotated to about 140 rpm. Then power is applied and the speed is gradually built up until the rotor rpm is at 200 rpm. Then full power is applied and a typical liftoff is around 40 mph. Landing is 0-5 mph.
Its not that loud...its a Subaru 130 horse engine. Most of the noise comes off the prop.
I wear a nice headset with gel seal earcups.
Stan' How slow can it go, as in ground speed? Top speed?
Armin: It can fly and maintain altitude at 25 mph with full throttle in a condition known as flying behind the power curve. If you slow up below this...it will start descending.
You can slow it completely to 0 mph and then be in a vertical descent...all the while having full control over it. You can kick in some rudder and spin as you come down vertically.
Top speed is 100 mph. It will cruise at 80...although I will be content at a 70 cruise as it just saves on the engine.
A gyrocopter will not stall like an airplane. The rotor has enogh airspeed to allow the gyro to slow clear to 0 mph. This is what is so safe about a gyrocopter. Should you have an engine out..you can practically land it in a rock pile.
Stan, thought you like this column from The Onion. I'm taking a copy to EAA meeting tonight. Titled, "I want to fly a Helicopter, not Look at a bunch of Crazy Dials!"
http://www.theonion.com/4006/opinion1.html
David Thomas Overlooking Cook Inlet in Kenai, Alaska
Dave: Thanks for the link. EAA is a great orginazation. You will notice their 50th anniversary decal that is on the nose of my gyrocopter right under the yaw string.
Edited 2/10/2004 8:17:58 PM ET by Stan Foster
"Altitude is more a function of the throttle setting..and speed is more a function of the tilt of the rotor. Its hard to explain but it all balances out while you are flying. If you want to climb...adding power will get you there."
Same as a airplane. The reverse of what most people think (and some pilots act). But it's true: Throttle controls climb. Elevator controls speed.
The best book on it and other aspects of light aircraft is probably still
Stick and Rudder: An Explanation of the Art of Flying -- by Wolfgang Langewiesche
60 years later, it is still all true. Plus he forecast the popularity and advantages of tricycle gear, etc.David Thomas Overlooking Cook Inlet in Kenai, Alaska
stan... most of the time i get those blobs it's dust in the air refracting the light..
another thing... have you bought one of those little pencil type things that look like a small suction cup on the end for cleaning your lenses... i've had great luck with one.. got it at Ritz Camera
nice pics.. you flying that to RI ? .. i bet you could hop from one Breaktimer's house to another all the way from IlliniMike Smith Rhode Island : Design / Build / Repair / Restore
Mike: I have no problem flying 2-300 miles...but I refuse to fly over solid wooded areas. I would be depending on my engine and I just would not be comfortable with that. I have had 18 forced landings since 1985..never damaging anything. But I was always in gliding distance of a pasture or a field.
The engine in the one I am building now should be much more reliable...but I am going to be content just flying in the midwest.
I have more switches and fuses installed. All the controls are connected and adjusted to correct fore.aft and lateral limits.
The windshield is on, dual fuel pumps. I should have it all wired and running by the end of January.
Stan--Be careful with that bird!
home.att.net/~raf2000owners/raf_accidents.htm
kman: Believe me...I am very careful. I have flown them since 1985 and have had many forced landings. They are the best engine out machine I know of because they basically land at or less than 5 mph.
They are like anything...you have to know the grey areas to stay away from...
Yup looks dangerous safer to have wings I think and a parchute!
Bluesman found sitting on toilet is said to be high on pot!
It has its own parachute....the rotor. That rotor has let me donw gently with 18 complete engine outs.
I'd imagine if the engine goes out now you remain pretty calm? How close to a heart attack did you come on the first one though?
Where is that place that we all can watch? Are there others around the states? Cool looking toys!
Please dont take this as tooting my horn...ok? But I took my gyro out to taxi today and spin up the rotor for the first time. In 45 minutes ...it was feeling so good...as I was learning proper rudder and cyclic reflexes...that I did some low and slow crow hops down the runway. It felt great.. I just had to be keenly aware of keeping it square with the runway with the rudders..and to stop any lateral drift with the cyclic.
After about 1.5 hours..I had enough. Time to let the reflexes soak in until the next time out. It would be very easy to just full throttle it and leave the airport...but I must be slow and methodical about training my reflexes.
Even though I have lots of experience in other gyros....this machine is a little more involved. It really is surprising me though how similar it is to my smaller ones I had.
Edited 2/11/2004 8:53:57 PM ET by Stan Foster
I want to ride, unh unh, can I, oh oh oh ,can I? LOL
Here is a picture of my 21 year old daughter ..Jennifer..awaiting her first flight. It will be getting its airworthiness inspection Feb.28th. If the DAR says all is ok...it will be a legal eagle.
Gorgeous, Stan! I mean really! The 'copter's pretty cool, too.
I feel cheated, though, having read in Popular Mechanics/Popular Science/Popular Whatever back when I was a kid in the '60s that by the year 2000 we'd all be commuting to and from work in one of those. Well Y2K rolled around and . . . no gyrocopter. What a disappointment. Glad that dream came true for some of us. Hope to see one fly some time.
Back to work . . .
Stan, thanks for the pictures, that really is going to be a nice ride when you get it
completed. More pictures, please
It would be way cool to show up at the job site in that. Just put a wire cage under the cockpit for your tools'-)
stan i have a buddy that rides a white police special harley with just about the same picture on his tanks as in raf1.nice looking toy bet its fun
