hammer drill chuck loosens
WmGalloway | Posted in Tools for Home Building on March 3, 2008 06:25am
My two year old Bosch hammer drill has a bad habit of the chuck loosening up after a few seconds of drilling in concrete. Doesn’t matter if the drill bit is brand new or used. Drilling 5/16, 3/8, and 1/2 holes the chuck loosens up on all of them.
What’s my remedy???
  1. roger g | Mar 03, 2008 06:33pm | #1
    Don't they all do that!
    I try to keep my hand(lightly) on the chuck when it's turning.
    roger
    IMERC | Mar 03, 2008 06:39pm | #2
    needs cleaning and lubrication...
    WOW!!! What a Ride!
  3. CCI | Mar 03, 2008 07:01pm | #3
    Do you tighten all three holes in the chuck?  The proper way to tighten a chuck is to snug down each of the three holes to align the bit in the jaws and then go back and torque each jaw firmly to actually hold the bit.  If the bit is not aligned the jaws don't grip the shank of the bit and the chuck can loosen and the bit gets scored.  Once the bit is scored it is very hard to get it to hold in the chuck since the bearing surface of the jaw/bit interface is minimal.  Do it enough and the jaws of the chuck become worn.
    In normal drilling this is not critical but still good practice.  For heavy duty work it is very important.
    1. WmGalloway | Mar 04, 2008 08:28pm | #5
      Do you tighten all three holes in the chuck? The proper way to tighten a chuck is to snug down each of the three holesAh, no.... I've worked as a patternmaker using big drills and the like I've never been told to do that. Can't hurt I will try it. Thanks all for the advice.
    IMERC | Mar 03, 2008 07:03pm | #4
    another thing..
    after a couple of times of loose chuck...
    the jaws are about shot...
    WOW!!! What a Ride!
