Hammer Drills Reverse setting
ak_retired | Posted in Tools for Home Building on May 12, 2016 04:09am
I’m overhauling an old RV and can’t remove some rusted screws with my drill driver.  Will a hammer drill driver have the extra torque in reverse mode to break loose these rusted screws?
  1. jimmiem | May 12, 2016 04:15pm | #1
    Impact driver should do it.
  2. calvin | May 12, 2016 07:03pm | #2
    AK
    Zep has a killer penetrating nut buster, better I think than most.  Soak the hell out of the screws!
    take a matching screw driver if not nuts and put it in place on the screw.....firmly tap on the end of the screwdriver with a hammer several times to break the bind (bond) of the rust around the threads.
    then an impact driver might have a chance.  Use low setting first and push hard.  The screws might snap with the force, so I usually pop it a few times, reverse, fwd and then a couple more pops.
    Then there's always an easyout.
  3. DanH | May 12, 2016 07:57pm | #3
    A hand impact driver is often a useful tool for breaking free recalcitant screws.
    http://www.sears.com/craftsman-impact-driver/p-00947641000P?sid=IDx01192011x000001&gclid=Cj0KEQjw09C5BRDy972s6q2y4egBEiQA5_guv_-GegolfH_IqNBkje0UjTnahxOvYwVjDDHfO4OJ1lQaAiWt8P8HAQ&gclsrc=aw.ds
      MarkH | May 13, 2016 11:45pm | #6
      Those are great tools, but why do they always come with the Mega Size bits?  Really, I don't get it. I usually use a 3/8 to 1/4 inch adapter with a 1/4 inch socket and a quarter inch drive bit of some type that falls out everytime I turn around.  Still gets the job done once in a while.  Usually the head fails, sometimes the bit fails, and probably most of the time the screw loosens.
  4. renosteinke | May 13, 2016 06:14pm | #4
    It Won't Work
    Hammer-drills hammer the bit forward as it spins. There is no help to turning the bit. As such, they don't hammer at all in 'reverse.'
    You are thinking of an impact driver, which hammers the bit in the direction it rotates. Those apply equal impact in either direction.
      MarkH | May 13, 2016 11:39pm | #5
      Uh, no.  Hammer drills hammer the bit down in forward and reverse.  This can help remove screws due to the hammer action, but an impact driver works much better.
