Hammer drive anchors in concrete floors and walls, how to remove them?
jbgood75 | Posted in General Discussion on October 2, 2019 11:14am
How to remove metal stud tracks from concrete floors and walls when they have these hammer/pin driver anchors? Photos provided…
  1. florida | Oct 02, 2019 11:46am | #1
    Those look like drive pins which expand at the bottom. Trying to pull them out will make a huge hole in the concrete and frustrate you. Use a grinder to cut them flush.
  2. bobbomax | Oct 02, 2019 09:46pm | #2
    Like Florida Man says, grinder.
    A trick I learned from some smart Limey carpenter on YouTube- when you're installing expanding anchors, if you have room, over drill them- then the next guy can drive the pin or bolt through the bottom and patch the remaining hole.
    So before you use the grinder, try over-driving the pin- somebody might have been looking out for you.
    1. jbgood75 | Oct 02, 2019 11:02pm | #3
      What kind of tool would I use to try and drive it in further? Sorry, I’m a diy’er, not a professional. Thanks!
      1. bobbomax | Oct 03, 2019 02:48pm | #4
        Basically, whatever works.
        A piece of rebar, a bolt or screwdriver you don't mind messing up a bit or a 40d nail, Search on "punch" at the Harbor Freight site.
        If you're good with a ball peen hammer, that can get it low enough to not cause problems, although probably not low enough to allow a durable patch.
        1. florida | Oct 04, 2019 10:37am | #5
          Not one chance in one hundred of anyone doing that.
          1. makita888 | Oct 12, 2019 06:01am | #6
            They are called rawls and if you use an oversized drill bit they should just pop out
  3. florida | Oct 12, 2019 02:55pm | #7
    makita888
    Only if you buy the Rawl brand, otherwise they are drive pins or a quick drive anchor. They are made by many companies.
