Question:What is the best way to produce a hand-planed finish on S4S Douglass Fir beams already installed? I would appreciate it if the answer included strategies for getting into tight corners as well as for working next to other vulnerable surfaces, i.e. plaster, smooth wood, wall paper, etc. I speak of a natural planed surface with low ridges and depressions, not a decoratively scooped surface or a scalloped adze look. Bidding this at a reasonable price is a must, so appropriate techniques cannot take forever. Job scope is 3000 sq. feet.
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
A hand planed finish at a reasonable price on beams already installed ? ho ho ho. The reasonable price went out the window when the beams were installed before planing and then protecting. I realize that you are probably coming into an existing structure for an update/remodel, but this is just tedious hand work and scaffold building. You can find every hand plane you will need for the job at:
http://www.lie-nielsen.com/
Did you ever consider sanding instead ? Did you do a sample ?
*"Bidding this at a reasonable price is a must"Look in the dictionary under "oxymoron." I think you'll see a drawing of this very project being "bid at a reasonable price"
*Jeff, Start off with a good quality hand power planer. I like Bosch but whatever brand you like. One or two passes will get you 99% of the area probably. A baker type scaffold or any scaffold on wheels will expedite the work. The tricky or should I say time consuming part is the 1+% that truely needs to be done by hand. A sharp bull nose plane is handy here or you can always use a slick or 2" framing chisel. Feather in from the power plane stop and you should be okay. The final look is what is important. So use a good eye and you will be okay.walk gooddavid
