Hand-Truck tire Rx
MisterT | Posted in Tools for Home Building on June 13, 2009 07:18am
I am posting this in the general discussion area, as it maybe too controversial for the Tavern.
I have a dolly (told it would be racy).
with inflatable tires (never thought I would be using “inflatable” and “dolly” in the same post)
(not here at least)
the tires have tubes.
one is constantly in a state of flatness.
I used most of a can of fix-a-flat on it, but it still remains barometrically challenged.
so I removed the wheel and tire and tube and used the soapy water method and the Gunner-approved hold it underwater method.
but I don’t see any bubbles
should I be holding it underwater in the bathtub of a sleazy motel room??
I can’t see any leaks @ the valve stem.
WHAT am I doing wrong??
thanx in advance..
“After the laws of Physics, everything else is opinion”
-Neil deGrasse Tyson
If Pasta and Antipasta meet is it the end of the Universe???
according to statistical analysis, “for some time now, bears apparently have been going to the bathroom in the woods.”
    IMERC | Jun 13, 2009 07:21pm | #1
    replace the valve stem innards...
    WOW!!! What a Ride!
    1. aworkinprogress | Jun 13, 2009 07:25pm | #2
      How about using a "solid" tire I love them long time {even though they can not be blown up}
        IMERC | Jun 13, 2009 07:26pm | #3
        or the flat proof foam core....
        put in a new tube...
        WOW!!! What a Ride!
        1. aworkinprogress | Jun 13, 2009 07:35pm | #5
          Exactly my choice , just what the doctor should have ordered.
    2. MisterT | Jun 13, 2009 07:30pm | #4
      that is plan Bbut whyfor is it not leaking now??I have heard of filling tires with polyurethane foam.I wonder if I could put a little water in for curing and fill it with my great stuff gun and have it work??could be a mess and if it didn't work it I'd definitely be replacing the tire..
      "After the laws of Physics, everything else is opinion" -Neil deGrasse Tyson
      according to statistical analysis, "for some time now, bears apparently have been going to the bathroom in the woods."
        coonass | Jun 13, 2009 07:44pm | #6
        T,Throw away the Fixaflat and get some Slime. Not only will fix this leak but prevent future ones. Foam is a bad idea, don't ask how I know! My local hardware carries Slime and so does WallyWorld.http://www.slime.com/KK
        1. rasconc | Jun 13, 2009 08:28pm | #12
          Slime as just said.  Wal-Mart is usually cheaper than Lowes or even Harbor Freight.  I go for the gallon and do lawn mopwer tires and everything but trailer tires.  It says not for tube but seems to work fine.  Make sure you spin the tire after putting it in.For those who have fought for it Freedom has a flavor the protected will never know.
        IMERC | Jun 13, 2009 07:52pm | #7
        heard tell about the foam.....
        10 pounds in a one pound sack....
        gets amussing...
        and messy....
        use the slime....
        and change the stem core...
        it knows when yur watching and won't leak till ya turn yur back....
        WOW!!! What a Ride!
        1. MisterT | Jun 13, 2009 08:02pm | #9
          if/when I go out today I'm picking up a valve core and some slime.....
          1. seeyou | Jun 14, 2009 12:25am | #20
            I second or 3rd the Slime. I bought Slime tubes for my wheelbarrows. They may have the right size tube to fit your tire.http://www.quittintime.com/      View Image
            maddog3 | Jun 14, 2009 01:24am | #24
            be careful not to get any slime in the dollys eye and you have to run her around the yard for about five minutes to make sure the slime coats the whole inside of the tire.
          3. AitchKay | Jun 14, 2009 05:01pm | #34
            I shot some Fix-A-Flat into a wheelbarrow tire about 25 years ago. The, instead of running around the yard with it, I propped it on the shaft of an old washing-machine motor, and left it spinning.The next-door neighbor kept looking over the fence and staring at it all afternoon.But he was a, "Don't Ask, Don't Tell," type of guy.AitchKay
            maddog3 | Jun 14, 2009 05:21pm | #35
            learn that trick from junkhound did ya ....?damn we're ingenious when were lazy" Hard work pays off in the future,
            Laziness pays off now " Steven Wright.
          5. doodabug | Jun 14, 2009 05:28pm | #36
            You have to be lazy to be efficient.
            maddog3 | Jun 14, 2009 05:47pm | #37
            see, you know I know what I'm talking about :)Good Morning.
          7. doodabug | Jun 14, 2009 06:10pm | #38
            Morning, How is the ladder climbing doing?
          8. User avater
            maddog3 | Jun 14, 2009 06:32pm | #39
            still pretty much clim like a 2 yea old ... both feet on each step, the doc was having a coronary when I told him some of the things I've been up to.
        BillHartmann | Jun 13, 2009 09:29pm | #14
        You are just not testing it with enough pressure.Pump it up to about 150 psi and you will find the leak.
          IMERC | Jun 13, 2009 09:46pm | #15
          why stop at 150???
          WOW!!! What a Ride!
        2. MisterT | Jun 13, 2009 10:18pm | #17
          my compressor's high cut-off is 125 psi....
            BossHog | Jun 13, 2009 10:33pm | #18
            Just waned to mention that after you stick a tire under water it may take a while for the leak to show up. They can really be a bear to find if they're small ones.
          2. Tomrocks21212 | Jun 14, 2009 12:22am | #19
            Could someone explain to me what possible sdvantage there is to pneumatic hand truck tires?They always seemed much harder to roll than solids, regardless of the air pressure. Not to mention the flats.Seems to me like an answer to a question that nobody asked.
          3. DonCanDo | Jun 14, 2009 12:50am | #21
            A solid tire is going to roll easier on a smooth surface.  A pneumatic tire is going to roll easier over a rough surface.  Tire pressure can be set high for smooth surfaces and roll ALMOST as easily as a solid tire.  Conversely, pressure can be set lower for rough surfaces and will roll a LOT easier than a solid tire.
          4. Tomrocks21212 | Jun 14, 2009 01:10am | #22
            Okay, I guess I could buy that. It hasn't been my experience, but maybe the inflatables I've used were too small in diameter.
            Plus I didn't like the "give" and the general squishiness.
            IMERC | Jun 14, 2009 06:02am | #26
            fill it twice...
            take it to 250...
            WOW!!! What a Ride!
          6. danski0224 | Jun 14, 2009 07:09am | #27
            I have a cylinder of nitrogen...
            The nitrogen will help the tire last longer...
            Cylinder pressure is good at 2500 psi, give or take a fuzz
          7. User avater
            IMERC | Jun 14, 2009 08:05am | #28
            the things we do around here for cheap thrills.....
            WOW!!! What a Ride!
          8. danski0224 | Jun 14, 2009 03:28pm | #29
            Just trying to do my best to help.
            Obviously, an air compresor with a cut out at 125 psi is no good for finding leaks.... plus, there is all that oxygen in compressed air to deteriorate the tube....
          9. Piffin | Jun 14, 2009 03:55pm | #31
            Y knot Hydrogen?
          10. User avater
            Dam_inspector | Jun 14, 2009 04:01pm | #32
            Leaks too fast, and the dolly floats away.
            OH, yeah, its EXPLOSIVE!!!
          11. danski0224 | Jun 14, 2009 04:02pm | #33
            I just don't have any hydrogen on hand.
            I have some acetylene, but it gets unstable at pressures above 15 psi....
  2. ANDYSZ2 | Jun 13, 2009 07:56pm | #8
    I think a replacement tire and wheel is less than 20$ or a new tube.
    ANDYSZ2
    WHY DO I HAVE TO EXPLAIN TO FRIENDS AND FAMILY THAT BEING A SOLE PROPRIETOR IS A REAL JOB?
    REMODELER/PUNCHOUT SPECIALIST
  3. danski0224 | Jun 13, 2009 08:08pm | #10
    I had my hand truck tires filled at a place that fills heavy equipment tires... costed about $40 apiece. It is also a ballast, so the tires are heavy now... but no flats.
    Off the shelf no flat/foam tires were not available in the size I need for that hand cart... I can only buy new tire/tube/rim combos for mine at $50 each.
    Products like Great Stuff will not work well.
  4. Oak River Mike | Jun 13, 2009 08:20pm | #11
    The "never flat" tire is like $20 at Lowes and all the other items mentioned at around the same cost.  A new hand truck is around $50.....
    I'm just sayin'  ;)
  5. mrfixitusa | Jun 13, 2009 08:34pm | #13
    Is this anything like the carts at home depot with the square wheels?
  6. Zorrohood | Jun 13, 2009 10:04pm | #16
    A solid tire will cure all problems.
  7. bobbys | Jun 14, 2009 01:22am | #23
    I have 3 handtrucks which are always in a "I have a flat tire State of mind".
    I have tried to reason with them, tried to be nice by putting them in a shed, Cussed at them, Yelled at them, Carresed them with love, Set fresh cut flowers on them but alas i yam always repaid with a flat tire .
    I think they just mock me but i cant figure out why.
    If they keep it up i am going to paint them with mismatched paint and lend them out to scoundrels that never return items.
  8. User avater
    Dam_inspector | Jun 14, 2009 05:31am | #25
    Pour napalm on tire.
    Apply flamethrower to dolly tire.
    Enjoy show.
    Buy new dolly.
  9. Piffin | Jun 14, 2009 03:51pm | #30
    Buy some hard rubbers to replace those inflatables
    1. MisterT | Jun 15, 2009 03:37pm | #40
      yeah I'll spend 80 bucks to fix a 60$ dolly...You work for AIG???.
      1. Piffin | Jun 15, 2009 04:39pm | #41
        I've got a $39 dolly that I spent $30 on for hard rubber tires and considered it a bargain. One tire on it went flat right after I had fixed and slimed three wheelbarrow tires that same summer and I was getting sick of dealing with them.I think I got the tires from Wallyworld
        1. MisterT | Jun 15, 2009 04:59pm | #42
          Actually I have a 20 YO Grossmans wheel barrow that was 30$ that has a 45$ tire and a couple of new handles and a bout 30 hours of farting around with the old tire before the switch...I like the inflatable tires on the hand truck.but if the slime don't work & I got to frick around with it any more I'm gonna prolly go solid..
  10. ANDYSZ2 | Jun 16, 2009 03:17am | #43
    Northern is selling 10" pnumatic tires for 4.99 half price for fathers day.
    ANDYSZ2
