Hanging drywall in off-angle corners
Ewan | Posted in Construction Techniques on April 28, 2006 05:15am
Hello all,
Hoping for some advice on hanging drywall on a sloped ceiling where it meets the flat ceiling and/or kneewall.
Where the drywall panels meet in these off-angle corners, is preferable to hold the sheets back slightly from one another so neither is ‘passing thru’ the other? Alternatively, if one sheet is run past the other, does the small triangular void cause any problems with taping? (assuming a Trim-Tex type vinyl inside corner bead is used).
Many thanks.
Ewan
  1. dirtysanchez | Apr 28, 2006 05:40am | #1
    line up the two paper face edges and your good. if everything (all the intersections of the wall) is good we sometimes rip on the back and leave the face intact and it creates a straight line. trim tex makes an excellent product called magic bead. used it a lot and no cracks in these off angle corners.
    1. Ewan | Apr 28, 2006 05:53am | #3
      Thanks dirtysanchez for the reply... much appreciated.Ewan
    basswood | Apr 28, 2006 05:50am | #2
    "hanging drywall on a sloped ceiling where it meets the flat ceiling and/or kneewall."
    I like to cove those corners with this tool after taping as usual.
    1. Ewan | Apr 28, 2006 04:11pm | #4
      Thanks basswood... I'd pitched the rounded-corner option but DW kiboshed that idea.
      Ewan
Fast, Accurate Wall Framing
