Hanging drywall on truss ceiling ?’s
user-159210 | Posted in General Discussion on September 27, 2007 02:51am
Have a 22 x 24 detached garage that I am going to finish the interior. The roof trusses are  24″OC and the height of the walls are 10 ft.
Can I use 1/2″ drywall on the ceiling or will it sag? I will be hanging this myself and would like to avoid the weight of 5/8″ rock.  Thanks- Paul
  1. CAGIV | Sep 27, 2007 02:56am | #1
    you could strap the ceiling if you really wanted to use 1/2".  I'd advice against using 1/2"at 24" O.C.  Then again it is a garage.
    If you use 5/8", or 1/2" for that matter, rent a sheetrock lift if you plan on doing it yourself, it will be money well spent.  You can acheive the same end result with a few T-Braces, but a lift makes the whole project that much easier.
    Team Logo
    1. user-159210 | Sep 27, 2007 03:24am | #2
      If I were to strap the trusses what would you recommend, the trusses are 2 x 6's
    McDesign | Sep 27, 2007 03:30am | #3
    I'd do it.  I have, and have never seen a sagging problem that everyone warns against - using Johns-Manville Spider blown-in fiberglas.  maybe it's just lighter and fluffier?
