Hanging Heavy Bag from Floor Joists
georgep | Posted in Construction Techniques on February 6, 2017 12:02pm
I am going to be hanging a 100lb heavy bag from the basement floor joists  and am wondering what is the best way to distribute the weight. The bag will be hung using the hanger in the picture.  Methods I thught of  are:
1- lag bolt a 2×4 that spans 3 or 4 of the joists then attach the hanger to the 2×4,  either between two joists with bolts and nuts or directly under and into a joist with lags.
2-  lag bolt a 2×4 in line with a joist and lag bolt the hanger into the 2X4 and joist.
What do you thinkk?
  1. DanH | Feb 06, 2017 01:17pm | #1
    If the joists are to code then probably you do not absolutely need any reenforcement, but I'd be inclined to use something similar to #1, though perhaps using cross-bracing or solid blocking between the joists rather than just a 2x4 lagged to the bottom.
    Mainly you're trying to control "bounce".
  2. florida | Feb 06, 2017 04:50pm | #2
    Screw a 2 X 4 across the bottom of 4 floor joist and hang your bag in the middle. That will spread the load and reduce vibration upstairs.
  • A Postwar Comeback
  • Natural Simplicity
