hardi plank nailing
patmando | Posted in Construction Techniques on May 30, 2009 11:37am
I’m getting ready to install Hardie Plank siding on my house.  The only unusual part of this is that I’m installing it over 1″ Poly Iso rigid foam.  I’m wondering if a 2 1/2 ring shank siding nail is going to be long enough considering I need to go through 3/8″ hardi + 1″ foam + 1/2″ sheathing before I penetrate the studs.   This leaves about 5/8″ of penetration into the studs.  Is that enough or should I use my framing nailer and shoot around a 3″ nail?  Anyone have any experience with this that could make a recommendation?
    Dam_inspector | May 31, 2009 12:07am | #1
    I think you're OK (just barely though) with a 2 1/2" nail.
  2. jimcco | May 31, 2009 03:19am | #2
    There have been recient posts on that issue and some were concerned you would get sagging ofer foam with nails.
Outdoor Lighting
