Hardie Plank Nailing
patmando | Posted in General Discussion on June 1, 2009 05:57am
Sorry to post this again but I think I had it in the wrong category.    I’ve reviewed the many posts regarding issues similar to this but haven’t found anything that speaks exactly to my question.
I’m getting ready to install Hardie Plank siding on my house.  The only unusual part of this is that I’m installing it over 1″ Poly Iso rigid foam.  I’m wondering if a 2 1/2 ring shank siding nail is going to be long enough considering I need to go through 3/8″ hardi + 1″ foam + 1/2″ sheathing before I hit the studs.   This leaves about 5/8″ of penetration into the studs.  Is that enough or should I use my framing nailer and shoot around a 3″ nail?  Anyone have any experience with this that could make a recommendation?
  1. PedroTheMule | Jun 01, 2009 07:13pm | #1
    Hi patmando,
    I'm getting ready to install Hardie Plank siding on my house.  The only unusual part of this is that I'm installing it over 1" Poly Iso rigid foam.  I'm wondering if a 2 1/2 ring shank siding nail is going to be long enough considering I need to go through 3/8" hardi + 1" foam + 1/2" sheathing before I hit the studs.   This leaves about 5/8" of penetration into the studs.  Is that enough or should I use my framing nailer and shoot around a 3" nail?  Anyone have any experience with this that could make a recommendation?
    Screw verticle 1/2" treated plywood furring through the foam 16" oc and nail away on the Hardie in the same fashion you would without the foam.
    Pedro the Mule - Good choice using foam
      IMERC | Jun 01, 2009 07:17pm | #2
      if you mail directly to the foam will have a wavy surface that will be almost impossible to control....
      nail to firing strips
      WOW!!! What a Ride!
      1. PedroTheMule | Jun 01, 2009 07:32pm | #3
        Hi IMERC,
        Furring strips are what I recommended.....not sure where the misunderstanding is??????
        Pedro the Mule - Clarify Please
          IMERC | Jun 02, 2009 12:10am | #4
          Hey Pedro....
          guess all the reply buttons look the same....
          meant to post to the OP...
          WOW!!! What a Ride!
          1. PedroTheMule | Jun 02, 2009 12:58am | #5
            Hi IMERC,
            That's cool.....thougt I'd not clarified my post....take care my friend.
            Pedro the Mule - always about having fun....or at least having fun....
