Hardiplank gaps and looseness?
| Posted in Construction Techniques on July 9, 2003 07:51am
Sorry for the cryptic subject! I’m currently installing pre-finished Hardiplank over OSB sheathing and Tyvek. I’m blind nailing into studs following James Hardie’s directions using Hitachi Hardinails. Basically, I think I’m doing everything right (at least relating to the siding installation!). The siding planks are ending up surprisingly loose – many show a little gap between themselves and the plank below them. If I press on the plank the gap closes up, but then it opens again when I release the plank. Is this normal? Have I done something wrong? Does it matter?
  1. zcnsc | Jul 09, 2003 01:36pm | #1
    Try turning down the pressure on your compressor.
    If that doesn't work use small stainless steel finish nails on the bottom of the planks.
  2. butcher | Jul 09, 2003 04:05pm | #2
    I find that you have to use your hammer and smack everyone which tightens them up.
    1. jmarcus007 | Jul 09, 2003 04:41pm | #3
      Where do you smack them with your hammer? And why would the compressor pressure make a difference - the nails are being driven to the manufacturers required depth (ie flush or just a tiny bit proud)
      1. butcher | Jul 09, 2003 04:58pm | #4
        on top of the nail?
      2. zcnsc | Jul 10, 2003 03:34am | #5
        The compressor pressure makes a difference because you are lapping the siding.
        Too much pressure and the plank may bend even though the nail stays flush.
  3. RalphWicklund | Jul 10, 2003 04:19am | #6
    You could be nailing too high on the board which will not impart the ever so slight bend across the width of the board which helps hold it down. Your reveal may be too small for the width of the board, which will leave a gap.Your nails may be flush (or proud) but the board is still not tight to the wall. Handling the board or other than flat stacking could have stretched or bent the board so it will not close over the previous course. They can be finicky that way. Your wall may not be flush all the way across. If your studs are bowed or the edges of the OSB are of different thickness you can see gaps. You may be forced to face nail at some points.
    Edited 7/9/2003 9:22:54 PM ET by Ralph Wicklund
    1. timmy | Jul 10, 2003 01:46pm | #7
      have you checked that u have not put the nails in back to front , actually i have found that when ever i have done this particular job i'm using a #### load of glue what about u
  4. dwcasey | Jul 10, 2003 06:53pm | #8
    Are the nails getting a good hold in the OSB/Studs? How is the surface of the exterior wall? Is flat? Bumpy or wavy?
    I put up some HardiPlank on my home about 3 years ago and didn't have this problem. We were nailing on top of OSB and foam board in someplaces.
    What's your exposure? I believe the planks we used were 7 1/4 inches tall and you there is supposed to be a 1 1/4 coverage (or overlap) so 5 inches was exposed (or it might have been 8 1/4 and 6 inches).
    Edited 7/10/2003 11:54:24 AM ET by DW
    Edited 7/10/2003 11:55:09 AM ET by DW
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
