HardiPlank pallet
Wax1973 | Posted in General Discussion on February 23, 2011 04:06am
How many planks are in a pallet of HardiPlank? Local supplier told me they could discount if pallets are ordered, but the person on the phone was unsure of how many planks were in a pallet…??/
I’m looking at using the 8 1/4″ boards.
  1. Hokuto | Feb 24, 2011 05:22am | #1
    I assume you're talking about preprimed, not prepainted Hardie, since the prepainted (colorplus) is done order by order. Best place to ask would be Hardie. I ordered about 25 squares of Hardieplank (7-1/4") last year and I believe it was a total of about 420 boards or so (6" exposure, so 6 square feet per board). But mine was colorplus so that may make a difference. At any rate, I believe it came on three pallets, which were arranged three boards across on 2 pallets and 4 boards across on 1 shorter pallet--if memory is correct. That would make about 140-150 boards per pallet, for 7-1/4" boards. But if they load by weight, Hardieplank is 2.3 lbs/sq foot, so about 16.67 pounds per board, or 2334 to 2500 pounds per pallet. In the case of 8-1/4" boards that would be about 19 lbs per board, or 123 to 131 boards per pallet. But that's a lot of "ifs" there. Ask Hardie.
    1. Wax1973 | Feb 24, 2011 02:12pm | #2
      That helps
      Great, the weight helps me out as well. Thanks.
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
