Hardiplank: with or without furring …
newbuilder | Posted in Construction Techniques on September 6, 2007 03:09am
I’ll be working with hardiplank 6 1/4″ vertical siding for the first time as soon as my order gets in and I’m wondering just how crucial it is to fur-up the entire wall before fastening the hardiplank on.  I KNOW I’ve seen whole houses done in hplank where the plank is nailed directly to the cdx sheathing over felt.  If it’s calked well at the ends and painted with a quality product and the inside walls are well vapor-barriered to prevent too much moisture from coming through to the backside is there really much danger of rotting or moisture damage if you DONT stand it out from the wall with furring?
thanks –
  1. joeh | Sep 06, 2007 05:17am | #1
    There is a product made for this, it has little dimples in it so water drains off the Hardi.
    WeatherTrek is the name of it, I've used it and liked it.
    http://www.valeron.com/weathertreknew/
    Joe H
  2. Hackinatit | Sep 06, 2007 12:15pm | #2
    #30 tarpaper strips will do the trick...
    Troy Sprout
    "A free people ought not only to be armed and disciplined, but they should also have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government."
    -- George Washington
    1. newbuilder | Sep 07, 2007 02:23am | #3
      how would 30 lb felt keep a clear air-barrier for moisture flow and evaporation behind the hardiplank???   I don't get it.
      nb
      1. Hackinatit | Sep 07, 2007 05:38am | #5
        The felt firring strips act the same as any firring strip...
        air in bottom and out top for evaporation
        water down out the bottom (over the flashing). Troy Sprout
        "A free people ought not only to be armed and disciplined, but they should also have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government." -- George Washington
    2. rickjl | Sep 07, 2007 05:30am | #4
      Hackinatit <!----><!----> ,
      Any chance you could take a picture of the trim that is going over that boxed soffit?
      1. Hackinatit | Sep 07, 2007 05:45am | #6
        Sure, rickjl
        I used 1x and ext ply and primed all the cuts before installation.
        That corner trim is salvaged/stripped redwood from the deconstruction... it was the only thing worth keeping
        Troy Sprout
        Edited 9/6/2007 10:49 pm by Hackinatit
