Hardisoffit – Painting
rgm34 | Posted in Construction Techniques on October 23, 2006 05:48am
My father and I recently sided my house with Hardiplank Select Cedarmill. Nice stuff, just a little dusty when cutting the trim. I like the look of the Hardie Vented Soffit and would like to use it. My father thinks it’s going to be a pita to paint with all the holes getting clogged. We use Benjamin Moore paint, which is a little thick, so I understand his concern to a certain degree.
Does anyone have experience painting this stuff. I’d prefer to use something other than vinyl. He also thought I was nuts using HardiPlank but loves the look after it’s installed and painted so hopefully I can convince him on the soffit material.
Thanks.
Robert
  1. splintergroupie | Oct 23, 2006 08:00am | #1
    You could prime and paint before you nail it up so the drips go to the 'bad' side, use Floetrol in the paint so it works more smoothly, and/or spray the paint if you have the equipment.
  2. DonCanDo | Oct 23, 2006 02:16pm | #2
    I don't know what Hardisoffit looks like, but when I've had to paint stuff with small holes (like radiator screens), I've found that a roller works pretty good.  Keep the roller a bit unloaded.  That is, not fully soaked with paint and roll a little bit on a piece of scrap first to remove excess paint if necessary.
    You can even thin the primer to reduce clogging, but I wouldn't thin the topcoat.  Use 2 light coats rather than 1 heavier coat.
    Experiment first and let us know how it turns out.
  3. 741cp | Oct 25, 2006 03:35am | #3
    I did mine with a sponge roller, a coat of primer and color on the ground and then a second coat of color after install. The Hardie soffit is half holes, half solid. Load up your roller, roll it out a little on the solid part, then cover the part with holes.
    Another tip, since those holes are about 3/16, get a roll of insect screen, rip it to the width of the holes and staple it up before installing the soffit. It's thwarted about a million asian ladybugs on my house.
  • A Postwar Comeback
