hardwood floor
RobN | Posted in General Discussion on March 24, 2002 10:59am
I want to lay a prefinished hardwood floor in a cottage that is located in southern Ontario and the cottage is not winterized.  The current floor covering is resilient tile and is in very good condition.  I am wondering what precautions I need to take in order to lay this floor.  The outdoor temperature will be hovering around 10 celcius or 50 farenheit.  The cottage has a fireplace in case this makes a difference, otherwise there is no other heat source.
  1. PhillGiles | Mar 24, 2002 11:27pm | #1
    Rob, most of the manufacturers have websites, email addresses for help, and 1-800 numbers. The first thing I'd do would be to check with the manufacturer to find out if they'd recommend/warrantee such an installation.
    here's a start for you:
    http://www.woodfloorsonline.com/manufacturers/manufacturers.html
    http://www.floorbiz.com/
    Phill Giles
    The Unionville Woodwright
    Unionville, Ontario
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
