I just pulled up the carpet to replace it with oak flooring and there is carpet underlayment that is chip board above the subfloor that is OSB. My question is: can I lay the flooring directly on the underlayment or should I rip it out and nail directly to the OSB?
In this FHB Podcast segment, the crew offers expert advice on insulating an old home and finding the right contractor to do the job.
Chip Board? Is that the OSB? If you have two layers of sheathing , keep it . Most good floor experts recommend both a sub and sheathing under the hardwood.
Laying a strip floor on top of OSB and/or chip board is not a good idea. The diagonal blind nailing will not hold in either material. Your end result will be a loose floor.
If you want strip flooring then I would remove the carpet underlayment and install a minimum of 5/8 cdx plywood over the OSB. Use screws or ring shank nails to secure it to the joists thru the subfloor. Run red rosin paper between the sheets to help eliminate noise squeaks.
The other option is to use a wide plank floor and face nail or screw and plug. With this detail, you are fastening your flooring into the joists and not the subfloor. Again be sure to use paper between floor and subfloor.
david
walk good
Hi David,
I had OSB in my last home upstairs and I stapled/nailed the floor direct to it. It was two years old when I sold and moved. I never had a problem with it. Good to read you response. I haven't seen a Ken Fisher response in awhile either. GW
How thick is the underlayment you are considering removing? What type/thickness of "oak flooring" are you thinking of installing? Have you considered how the new floor will transition heightwise to any adjoining floors?
Fastening strip floor to chipbrd, (particle board), is a joke. Osb is marginal, but staples work well enough. I would remove the underlayment and make sure the subfloor is well fastened, paper and floor. That seems as perfect as is reasonable.
The height difference might decide the details, but this is interesting, gab about it for a while.
