Hardwood floor stain
| Posted in Construction Techniques on September 28, 2004 03:27am
Is there any difference between the stain used on hardwood floors and any other wood stains?  I assumed they are identical and that the floor finish is protected by the urethane.  The reason I ask is a friend has had some trouble getting her cherry floor to match her cabinets.  The cabinets are kind of a burgundy color, whereas the floor ended up looking more like Walnut.  I assumed the floor guy got the wrong color, what do you think?
  1. calvin | Sep 28, 2004 03:32pm | #1
    Yes, provided the floor and the cabs are the same species.  Even then, age, same wood, different tree or the way it was cut will change the finish look.  A simple test of scrap should have revealed the chance of matching and allowed some doctoring to bring it close.
    Quittin' Time
    MikeS | Sep 29, 2004 03:21am | #2
    Different results could be caused by different-
     1) Stain Manufacturers "colors" - one companys cherry might lean towards a natural shade while others like Bartly gel stain if I recall correctly has a purple look to it.
    2) Stain types- pigmented, dyes, toners, oil based, waterbased, and gel stains all can give different results.
    3) Sanding tecnique -intermediate and final grit.
    Mike
    Mike
    It's O.k. to think out of the box,           Just don't walk off of the plank!
  3. IanDG | Sep 29, 2004 04:39am | #3
    Cherry is photosensitive -- the color will change anyway over time. I agree that samples should have been made before staining the whole floor.
    IanDG
Fast, Accurate Wall Framing
