I am going to install new light braz. cherry prefinished flooring and want to know if tar paper or rosin paper is better.I want to keep noise and moisture to a min.
The most common way to make your own parging mix is to use either Type S mortar for block or Type N for brick and add a concrete bonding additive.
blainei,
In my experiences, I have used both. It seems the the NHWFA can't make up their minds about this either. To me rosin paper doesn't leave tar marks all over the floor. The standard from the NHWFA is now the 15# asphalt paper. What ever works for you though.
regards
FreddiG
