Hardwood flooring w 16 Ga finish nailer
Rickydidlidoo | Posted in General Discussion on January 25, 2006 05:48am
Hi Everyone,
Is anyone experienced with hardwood flooring can give some advice on using a 16 Ga finish nailer to do the job ?
I did a small bathroom floor 7×10 2 years ago and I haven’t had any squeak since then. But this time my project is much bigger.
Thx for any comments.
    JDRHI | Jan 25, 2006 06:08am | #1
    If you're talking about a solid wood floor, I'd consider myself extremely lucky not to have any problems as yet with the first project, and not test your luck with a second.
    My advice would be to rent a flooring nailer.
    J. D. Reynolds
    Home Improvements
  2. jaeger | Jan 25, 2006 06:34am | #2
    Go with a flooring nailer.  If time and ease are important using a flooring nailer will get you done 4x faster.
    Paul
  3. FastEddie | Jan 25, 2006 07:10am | #3
    Or get a floor stapler, which is not the same as a standard pneumatic stapler.  You probably won't find it at HD-Lowes.
    Fonzie | Jan 25, 2006 07:19am | #4
    We use the 16 g finish nailer (2 inch nails) in the areas where we can't use the Power nailer. I got an air Powernailer - mucho better - not just for the shoulder. I found it to be safer for the walls and everything of value to not be manually storing that much kinetic energy and trying to release it in the right spot. And, by the way, the air nails DO pull in.
  5. HeavyDuty | Jan 25, 2006 08:07am | #5
    I have done it with a 15 GA on pre-finished. If you already have the tool and don't want to rent a floor nailer it's a viable option.
    Make sure the chisel point is perpendicular to the tongue and the nails long enough to hit the joists. I would double nail at 8" O.C. and angle the nails to resist withdrawal. And yes sometimes you have to sink the odd nails with a nail set.
Two Ways to Test Windows
  • The New Old Colonial
