Hardwood Installation above unfinished poured basement
measureright | Posted in Construction Techniques on February 3, 2010 01:30am
Installing 3 1/4 x 3/4 ” raw oak in house with unfinished basement. Would welcome any suggestions on what to do beyond / instead of tar paper to eliminate possibiliity of moisture problems in the future. Thanks.
  1. fingers | Feb 03, 2010 02:29pm | #1
    Could you clarify? Are you putting the hardwood in the basement? over concrete? or on the regular plywood/osb subfloor of the first and or second floor level?
    1. measureright | Feb 03, 2010 02:45pm | #2
      Sorry to be unclear. Hardwood is going on main floor. Subfloor is Advantek. Will insulate appropriately basement ceiling/ main floor floor. I try to do things 110% to avoid trouble and call backs. It's been a couple of years since I've installed hardwood so I was wondering if there have been any meaningful advances I might want to consider. All that's been done previously was 30# felt below hardwood. Thanks.
        Jeff_Clarke | Feb 03, 2010 08:20pm | #3
        To answer your question, yes, there have been improvements in underlayment systems for wood flooring.
        I'd suggest that you use Fortifiber HWD-15 - http://www.tools4flooring.com/fortifiber-hwd15-hardwood-floor-underlayment-432-sf-roll-p-1225.html?___store=english_11239125331
        which is more of a moisture barrier than felt.
        1. davidmeiland | Feb 03, 2010 08:27pm | #5
          I'm not familiar with that
          I'm not familiar with that product, but if it's more of a vapor retarder than felt it's probably a good idea. In your situation the basement may very well have higher RH than the upstairs, leading to cupping of the flooring as vapor diffuses thru the subfloor. I tend to think that prefinished flooring will perform better in that situation as well, since the back is finished and the finish is also a vapor retarder. If you finish the basement with drywall on the ceiling, you'll get another bit of improvement.
          I installed prefinished 3/4 x 3-1/2 oak on the second floor of my shop building. The first floor is a slab and it's slightly more humid than the second floor, but it has been enough to cause a tiny bit of cupping of the flooring. My experience was that the finish on the flooring made changes in MC occur very, very slowly.
        2. measureright | Feb 07, 2010 08:32am | #8
          Thanks for the recommendation. Since my post, in talking with hardwood installer, we have decided to use Ten Oaks brand material with six side seal.
          tenoaksflooring.com/products/
          That plus the Fortifiber product should eliminate any possibility of moisture penetration and cupping. Anybody familiar with this product - pro or con? Appreciate the help.
        Jeff_Clarke | Feb 03, 2010 08:20pm | #4
  2. DanH | Feb 03, 2010 09:22pm | #6
    How does it make any difference whether the basement is finished or unfinished?
  3. davidmeiland | Feb 03, 2010 09:52pm | #7
    If there's a well-detailed
    If there's a well-detailed drywall ceiling below, vapor movement will be slowed.
  4. DanH | Feb 07, 2010 08:37am | #9
    Something I'm missing here:
    Something I'm missing here: They've been putting hardwood flooring over unfinished concrete basements for maybe 150 years now. Why is it suddenly difficult to do?
