Hardwood on Staircase
Design2Reno | Posted in General Discussion on December 31, 2006 10:42am
I would like to replace existing carpet on a staircase with some hardwood.  Does anyone have tips for this process or can point me to a good article or book?
Thanks, Dennis
  1. sotabuilder | Dec 31, 2006 04:55pm | #1
    start at the bottom and you will be really good at scribing by the time you get to the top. get the quart tubes of pl400 too.
    RichBeckman | Dec 31, 2006 08:42pm | #2
    Make sure that the trim on the side(s) is secure and won't move before you start.
    You don't want to fit one step in and then the second one is a bit tighter and the trim moves and now the first step has a gap at the end. If it's an open staircase then that shouldn't be a problem.
    Don't ask...
    I'm sure there is a template tool that you can use. If I ever do it again, I think that would be worth it to get one. You can jury rig with scraps of lumber, but that is a bit of a pain.
    Rich Beckman
    This signature line intentionally left blank.
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
