Installing T&G Maple flooring on a concrete slab?
I had planned on putting a new ‘floating floor’ on the slab, but then I was given the oppurtunity to retrieved a pickup truck load of 30-year old Maple flooring that was pulled up from an old gymnasium. What’s the best approach to install it? Do I need a vapor barrier, if so, what material?
Ricky
Do a search, that has been discused here quite a bit.
Also wait and you will get some answers.
just got a call on a sunroom bump out that i built 2 years ago matching existing slab const. vabor barrior before pour, 3/4 cdx glued & screwed for floor guys diagonal hardwood strip. floor is cupping in bump out not tie in. go there and see sprinkler system soaking my new work and mulch dumped to thick. thank you landscape illegal dummies
