I installed hardwood in my house about 3 months ago. The moisture content was anywhere from 6.8 to 8 percent. Fastforward 3 months and now I am getting some squeeks and popping sounds. These noises are coming from the end joints only. I am wondering what the cause was. I stapled the flooring approximately 6″ oc and each end. I am wondering if this was an install error that is causing these squeeks or the fact that it was cheap flooring. It was mill run prefinished oak flooring. There are no abnormal gaps showing ini the flooring now either.
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
bski
Going back to the beginning.
What type of subfloor did you have? Did you screw down the subfloor prior to installing the HW?
What was the moisture content of the subfloor? What kind of slip sheet did you use between the sub and finished floor?
I assume the ends were T&G'd also on your HW.
any heat runs under the locations that are making noise?
How far away were preceeding coarses end joints?
Try putting some talcom powder on and in the joints in question-brush it in the joint. Quiet it down?
Thanks.
5/8" underlayment ply over
5/8" underlayment ply over 1/2 ply ring shank nails every 6" glued together. tar paper. Don't remeber exact moisture content, but I know it was close to the flooring. Flooring was end matched and the squeeks are spred out throughout the room. Not necesarilly over the heat runs.
bski
Whelp, beats me.
The only future advice I would give is lap the joints with a longer pc.
There's a couple places there that the lap is only as wide as your foot..............however wide that would be.
I like to get at least 9" or so-more than just one nail away.
Very well could be a bogus staple (bent up rather than going deep into the sub.
or
I screw down everywhere-ring shanks hold well for those that I've tried to pull out, but a screw draws up/done the two layers.
(by ring shank-gun nails or those larger hand drive "underlay" ringshanks? Bigger heads than those we used to hand drive for thin underlay under lino? Not much ring on those shanks)
Yep, talcum powder.
And you should have made an effort to keep joints in adjacent boards a bit farther apart.
And you should make an effort to be less condescending. I said it was millrun flooring. Did the best I could with what I had.
Especially with millrun flooring, don't always blindly take the next piece. In addition to sorting out culls, you need to consider the length of the piece relative to others already in place, and pick a longer/shorter piece if it will help prevent adjacent joints from being "too close" to each other. Sometimes it's a good idea to put in place maybe 3 rows by 5 feet, to get the spacings right, then separate to do the nailing.
squeaks
What is the humidity in the house? Where is the house located? Did the flooring manufacturer recommend staples?
I dont know what the humidity in the house is, but I think its high because the windows freeze shut. I tested the floor moisture and it has dropped to around 6% now. I am located in North Dakota. It really seems like it could just be because its cheap flooring. The movement causing the squeeks is coming from the groove side of the end joints. The flooring doesn't move along the stapled tounge. Or maybe I am just trying to make myself feel better about a poor install. I just don't want to make the same mistake in the future.
If the flooring mc has gone down the house relative humidity has probably gone down and maybe the floor has dried and shrunk enough to squeak. Isn't this what happens in the dry winter months? No squeaks 3 months ago? Get a humidistat and see if it's lower than it should be for a happy floor. Did your manufacturer's instructions indicate the relative humidity range that the house should be kept at?
Acclimation?
Cheap HW flooring huh? I've been tempted too....
I'm curious how long you let the flooring get acclimated to the install environment before starting installation?
Even with a high-quality moisture meter, stuff that reads "OK" may need more time to 'relax' in it's new quarters before being permanently fastened. It's been thru a lot going from bole to plank, every step adds stress that takes time to stabilize... if in fact it ever does.
It acclimated for over a month. Truthfully, though, I never unpacked the boxes. I did set them on spacers, but that was it. It could be because it has dried down more, but it hasn't dried enough to leave gaps. I live in a weird house. As I said earlier, the windows freeze shut when it gets really cold, and they are all new windows, and not cheap ones at that. Even the previous windows did the same thing, so I wouldn't think that its too dry in my house. I guess next time I will dry it down a little more before I install. Is it possible the price point of the flooring would pay a role?
Are you suggesting that there's little valuable use in measuring the difference in the MC of the subfloor and the finish flooring? They should be close to each other, no?
Yes they should be close in MC, closer the better.
Of course there's value in any information one might have available about the materials one intends to put into service. It's important too how one makes use of such information.
In this instance MC may not be as significant as the overall quality of the product.
There's reasons why suppliers charge more and collect it for higher-end material if it's proven such stuff performs better once installed. Less costly flooring may be cut from wood that's got internal stresses that won't be evident immediately.
(Remember the Chinese drywall debacle from a few years ago?)
Too, if cost is a major concern there may have been insufficient quantity of flooring available to complete the job without some pieces going in that would have been better off being tossed into the trash.
Inescapable fact of life: you get what you pay for... unless it involves government.
sp
You were doing pretty good until you laid down this statement.
seems to me....
the fact that the squeaks are at the end joints suggests that it is more likely funky milling or the butt joints being a little too close in adjoining rows. Some times the latter is really hard to avoid.
I'm a big fan of construction staples in a lot of situations but not for flooring. My very unscientific tests of L cleats vs. staples favored the cleats. For what it's worth I'm on my third hardwood floor in the last year, all using radically different sourced/milled wood.
